during the boot up process it says i need to login ?
(When looking for a solution to a problem you are facing, providing a structured, detailed description of the problem will help others provide a quick response)
(I am tried to enable public registrations in Matrix Synapse app and got an error.)
- (Login to FreedomBox.)
- (Go to Matrix Synapse application page.)
- (Click on the install button.)
- (Select ‘Enable public registrations’ option.)
- (Click on ‘Update setup’ button.)
(I expected to see a message confirming the settings were updated.)
(I get an error with the following message:)
(Updating configuration failed: error reading configuration file.)
(a screenshot of the screen/webpage when the problem was shown)
- FreedomBox version: (from Help → About page)
- Hardware: (name of single board computer or server hardware with architecture)
- How did you install FreedomBox?: (‘bought pre-installed hardware’ or ‘apt install freedombox’ or ‘downloading testing images from https://freedombox.org’ or ‘using a cloud image’)
