(When looking for a solution to a problem you are facing, providing a structured, detailed description of the problem will help others provide a quick response)
Unable to use SEARX with TOR
- install TOR
- INSTALL SEARX
no link
Auto Link TOR to SEARX with a checkobox?
functionality not there.
Steps To Implement:
- Install tor
- Install searx
- go to shell of debian run the following command
pip install -U requests[socks]
Edit the /etc/searx/settings.yml file
find the line “outgoing:”
And make it look like this (or just add proxies lines following)
outgoing:
pool_connections: 100
pool_maxsize: 10
request_timeout: 20.0
useragent_suffix: ‘’
proxies:
http:
- socks5://localhost:9050
https:
using_tor_proxy : True
extra_proxy_timeout : 10.0 # Extra seconds to add in order to account for the time taken by the proxy
You’ll also want to disable all the SEARCH engines that need CAPTCHA as Searx Doesn’t handle it at all, and they wont work. (Go to preferences and engines tab and disable!!!)
