Hello! I’m interested in setting up my Freedombox to connect to a VPN server. All external traffic (or only the mldonkey or transmission traffic) should be sent to the VPN server. When the VPN connection breaks or is refused or whatever, the traffic should be blocked.
I’m hoping some of you had the same idea and succeeded in making it work. I’d like to hear from you!
What I did so far: using the OpenVPN app is only for creating a VPN server, so
I used the instructions here to establish a VPN connection using SSH. Seems to work fine: The FreedomBox’ external IP address is the VPN’s.
Now, the next steps…?
Perhaps I can use firewall rules to make sure the traffic goes to the VPN or not at all, but what is the name of the FreedomBox firewall app? I tried the list here, but no success.
And does anyone have experience using vpnautoconnect on the FreedomBox?
I can’t give you reliable info or help, I just know that VPN in 19.2 is not working as expected (at least for me) and that there are issues. Not sure how that relates to your situation.
Every time I install OpenVPN on the raspberry PI 3 B+ it bricks my freedombox. I am willing to pay a bounty to get this working or even better WireGuard.
The OpenVPN works from my Android phone till freedombox reboots. Then it’s bricked.
OpenVPN making firewall inaccessible was a problem with firewalld in Debian. A work around was implemented in FreedomBox version 19.2. Could you check if the version you tried is equal or newer. Please note that if you are installing Buster, then version available there is 19.1
Other that this issue (needing version 19.2 for fix) there are no known problems with OpenVPN. It has been tested multiple times to work in 19.2 and in Pinoeer edition images.
@mray, The original post is about setting up a VPN client manually which we didn’t implement yet.
I am also an external VPN user and would love to get this to work.
Another way to get this to work is:
apt install network-manager-openvpn
Configure an OpenVPN connection on your GNU/Linux desktop in Gnome or KDE. Then copy the file /etc/NetworkManager/system-connections/MyOpenVPN.nmconnection to the same folder in FreedomBox.
Activate the connection.
Advantage of this approach is that network-manager will keep trying doing reconnections and will also start the connection on boot.
FreedomBox uses firewalld and we are not careful, the rules added outside of firewalld will be removed if firewalld gets restarted (dangerous). I have found instructions on how to block all traffic except VPN traffic. I have not tried the instructions myself. Some notes:
No need for masquerading rules.
You need to run the rules twice. Once with --permanent option so that they work after reboot (or firewalld restart). And once without --permanent so they get applied for current session (or instead just reboot machine).
Currently we are using nftables backend (newer) instead of iptables. You may have to convert those rules to nft.
It blocks all IPv6 traffic, needs tweeking.
It works for a specific outgoing IP to VPN. needs tweeking.
Just want to show support for coding this into the Plinth interface. If I understand correctly, connecting the FreedomBox to a VPN would solve the Carrier-Grade NAT issue (see Let's Encrypt "Failed to obtain certificate ...").
Apart from connecting to a remote server via VPN, we need to be diverting all the traffic coming to the public interface of that server back to the FreedomBox.
I’d like to know if anybody has found a solution to connect the freedombox all the time TO an openvpn server ?
Is there any vpn-client app/software that we could use ?
Hi,
Thanks for the shared interest in this issue and your replies!
I haven’t taken the time to delve into the issue more. Having a bit of a FreedomBox-fatigue.
Now I’m waiting for WireGuard to be implemented into FreedomBox. And Coquelicot (again), and also better (easier) external harddrive support.
At the moment my Olimex Olinuxino Micro board is not being used because of these things.
I’m going to keep an eye on the FreedomBox updates. I am confident that in due time it will become possible to use it as I had intended.
Kind regards,
Bart
create a virtual machine in virt-manager using the qemu image
access http://freedombox-local-IP in a web browser, taking freedombox-local-IP from the display in virt-manager
wait for it to be ready, create the admin user (here freedomdbox-adminuser), fill in the basic configuration, wait for software upgrades to be complete
Get the open VPN configuration (here it is using the VPN from FDN
nmcli con up id fdn-vpn-networkmanager passwd-file /home/freedombox-adminuser/vpn.txt
I have a DNS A record for the name myname pointing to the IP address of the VPN, after setting that name in the web interface for the freedombox, it automatically get’s a Let’s encrypt certificate and I can now access the freedombox from https://myname.
So it looks like there is at least no issue for port 443, I haven’t tested anything else yet.
The connection is visible in the web interface, but I couldn’t find a way to activate it from there. What would be needed is that the connection is automatically started at boot, I need to figure out how to do that.
Finally, I found how to make it automatically start:
$ sudo nmcli con mod fdn-vpn-networkmanager +vpn.data "password-flags=0"
$ sudo nmcli con mod fdn-vpn-networkmanager vpn.secrets "password=vpnpassword"
$ sudo nmcli con modify "FreedomBox WAN" connection.secondaries fdn-vpn-networkmanager
I restarted the freedombox virtual machine, then upon reboot, when checking Networks in plinth, I see it is connected, without having to do anything.
The question now is whether it will continue to work or not after a number of software upgrades.
