How to allow users to access Samba without Freedom box WiFi
Hi,
if I connect Freedom box to my WiFi, how is it possible to allow other users of that wifi to access Samba, (without needing to connect to the freedom box WiFi).
Thanks
Hello,
To better assist you, could you provide a bit more detail on your intended setup?
For others to access Samba shares on your FreedomBox, they’ll need to be on the same WiFi network. They can then connect to your FreedomBox using its local IP address or network name.
Could you let us know:
  • Has your FreedomBox been successfully connected to your router?
  • Have you already configured the Samba shares on your FreedomBox?
I hope you don’t mind the clarification request, but a bit more information would help us give you more precise guidance.
Looking forward to your response!
