Hi,
I need to pass through some hardware to the Home Assistant container. Where are the docker files located? The docs mention a config directory for HA, but the docker files are not there (maybe?). I tried making changes to the configuration.yaml in the config directory, but it does not work as intended. Not sure of the proper way to do this.
Thanks for the help!
Doug
