Trying to install I2P from plinth failed so did subsequent
apt install -f
- Login to FreedomBox.
- Go to I2P application page.
- Click on the install button.
- ssh into freedombox and execute
apt install -f
I expected the I2P application to be installed
I get an error with the following message from APT:
dpkg: error processing package ca-certificates-java (–configure):
installed ca-certificates-java package post-installation script subprocess returned error exit status 134
Could not load hsdis-arm.so; library not loadable; PrintAssembly is disabled
full apt log:
and this is the content of the log file mentioned in JRE error:
hs_err_pid314.log
- FreedomBox version: Debian GNU/Linux 10 (buster) and FreedomBox version 20.7. FreedomBox
- Hardware: Beagle Bone Black
How did you install FreedomBox?: I Downloaded the image from
the stable Beagle Bone Black page on freedombox homepage
And run it from microsd
