I have this question too. I’m doing the same thing right now - trying to figure out where my repository is When I installed gitweb, I created a repository, but I don’t understand how to find it in the terminal. There is no gitweb directory in the user directory
I see now that there is a way to create a repository with Plinth. Got to Apps > Gitweb > +Create repository. I expected this to be under Home > Gitweb for some reason, and didn’t notice it was under Apps > Gitweb.
@wind I will let you know if I find the location of repositories once I set one up.
So part of the issue was I made a user account just for Gitweb given the following information from the manual:
Note: If using this method, your password will be stored in plain text in the local repository’s .git/config file. For this reason, you should create a FreedomBox user who has only access to the gitweb and never use an admin account.
The Gitweb-only account has permission to “Read-write access to Git repositories (git-access)” and nothing else.
However, and unexpectedly to me, this user cannot create Gitweb repositories. Only the admin has access to Apps > Gitweb, where the create repository option is.
