Doing a fresh Pioneer install using the stable SD card image (this is my Pioneer with HDD, SD card had problems so I am doing a fresh install, HDD not wiped), after having accepted to use backports, after a while, plinth is back with this:
In English:
- “this app needs update, update now?”
- button “update”.
I tried to press “update”, after a long while of updating, I get the same screen again.
Some extracts of the journal here:
janv. 13 21:14:05 freedombox /usr/bin/plinth[13643]: # plinth..install(…)
janv. 13 21:14:05 freedombox sudo[14314]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions plinth install --write-fd 17
janv. 13 21:14:05 freedombox sudo[14314]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=110)
janv. 13 21:14:18 freedombox unattended-upgrade[5473]: [614B blob data]
janv. 13 21:14:18 freedombox unattended-upgrade[5473]: Preparing to unpack .../curl_7.88.1-10+deb12u5_armhf.deb ...
janv. 13 21:14:18 freedombox unattended-upgrade[5473]: Unpacking curl (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
janv. 13 21:14:19 freedombox unattended-upgrade[5473]: Preparing to unpack .../libcurl4_7.88.1-10+deb12u5_armhf.deb ...
janv. 13 21:14:19 freedombox unattended-upgrade[5473]: Unpacking libcurl4:armhf (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
janv. 13 21:14:20 freedombox unattended-upgrade[5473]: Preparing to unpack .../libcurl3-gnutls_7.88.1-10+deb12u5_armhf.deb ...
janv. 13 21:14:21 freedombox unattended-upgrade[5473]: Unpacking libcurl3-gnutls:armhf (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
janv. 13 21:14:22 freedombox unattended-upgrade[5473]: Setting up libcurl3-gnutls:armhf (7.88.1-10+deb12u5) ...
janv. 13 21:14:22 freedombox unattended-upgrade[5473]: Setting up libcurl4:armhf (7.88.1-10+deb12u5) ...
janv. 13 21:14:22 freedombox unattended-upgrade[5473]: Setting up curl (7.88.1-10+deb12u5) ...
janv. 13 21:14:22 freedombox unattended-upgrade[5473]: Processing triggers for libc-bin (2.36-9+deb12u3) ...
janv. 13 21:14:23 freedombox /usr/share/plinth/actions/actions[14316]: Initialized apps - apache, api, names, avahi, storage, backups, cockpit, firewall, config, datetime, diagnostics, dynamicdns, first_boot, help, letsencrypt, networks>
janv. 13 21:14:30 freedombox unattended-upgrade[5473]: quota not working (qgroup not set)
janv. 13 21:14:31 freedombox /usr/share/plinth/actions/actions[14316]: Error executing action: Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100.
File "/usr/share/plinth/actions/actions", line 93, in _call
return_values = func(*arguments['args'], **arguments['kwargs'])
File "/usr/lib/python3/dist-packages/plinth/privileged/packages.py", line 64, in install
with action_utils.apt_hold_freedombox():
File "/usr/lib/python3.11/contextlib.py", line 137, in __enter__
return next(self.gen)
File "/usr/lib/python3/dist-packages/plinth/action_utils.py", line 450, in apt_hold_freedombox
yield subprocess.check_call(['apt-mark', 'hold', 'freedombox'])
File "/usr/lib/python3.11/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100.
janv. 13 21:14:32 freedombox sudo[14314]: pam_unix(sudo:session): session closed for user root
janv. 13 21:14:32 freedombox /usr/bin/plinth[13643]: Error running action plinth..install(*(), **{'app_id': 'upgrades', 'packages': ['unattended-upgrades', 'needrestart'], 'skip_recommends': False, 'force_configuration': None, 'reinstal>
janv. 13 21:14:32 freedombox /usr/bin/plinth[13643]: Error installing package: Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100.
File "/usr/lib/python3/dist-packages/plinth/package.py", line 345, in install
privileged.install(**kwargs)
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 57, in wrapper
return _run_privileged_method_as_process(module_name, action_name,
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 116, in _run_privileged_method_as_process
return _wait_for_return(*wait_args)
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 154, in _wait_for_return
raise exception
janv. 13 21:14:32 freedombox /usr/bin/plinth[13643]: Setup completed: upgrades: Error updating app: Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100. Command '['apt-mark', 'hold', 'freedombox']' returned no>
janv. 13 21:14:33 freedombox /usr/bin/plinth[13643]: Error running setup - Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100.
janv. 13 21:14:33 freedombox /usr/bin/plinth[13643]: Unable to complete setup: Command '['apt-mark', 'hold', 'freedombox']' returned non-zero exit status 100.
janv. 13 21:14:33 freedombox /usr/bin/plinth[13643]: Will try again in 10 seconds
janv. 13 21:14:41 freedombox unattended-upgrade[5473]: Running kernel seems to be up-to-date.
The same error is repeated at 21:15:41, 21:17:00, 21:18:11, 21:19:57, 21:21:07.
Then I have
janv. 13 21:21:20 freedombox /usr/bin/plinth[13643]: Error executing command - ['sudo', '--non-interactive', '--close-from', '22', '/usr/share/plinth/actions/actions', 'plinth', 'is_package_manager_busy', '--write-fd', '21'], b'', b''
Then the first kind of error again at 21:22:04, 21:23:57, 21:31:04, 21:32:12, 21:33:19, 21:34:14, 21:36:13, 21:37:30,.
I left the Pioneer running, not sure what to do now.
