I did a fresh install on a Hetzner VM, following the commands here:
I checked the secrets file and it was generated.
Fresh install should give a web interface to continue setup.
Can’t access on either port
running netstat -plantu shows that there is nothing running on the http / https ports.
- FreedomBox version: latest
- Hardware: Hetzner CX21 (2 CPU, 4 GB Ram)
- How did you install FreedomBox?: ‘apt install freedombox’
The error I get in my browser is “ERR_CONNECTION_REFUSED”, which is reasonable considering the ports are not being listened to.
