I have installed Debian on my desktop using debian-10.1.0-amd64-netinst
After install i went in terminal and typed sudo apt-get update but there were no updates.
then i typed $ sudo DEBIAN_FRONTEND=noninteractive apt-get install freedombox
Everything seemed to work OK then it ended with processing a number of triggers for …
Rebooted but back in Debian
Tried $ sudo DEBIAN_FRONTEND=noninteractive apt-get install freedombox-setup
Cannot remember now what happened
Then tried $ sudo /usr/lib/freedombox/setup | tee freedombox-setup.log
but did not recognis commant
Tried rebootin - back in debian
How do i get into freedombox from here?
I followed the instructions on this page
https://wiki.debian.org/FreedomBox/Hardware/Debian
Just had another go
Can someone help me get Freedombox running on my desktop?
I have installed Debian 10 OK but did not use a root password, just a user password.
Used this page for instructions https://wiki.debian.org/FreedomBox/Hardware/Debian
Opened terminal
it fetched 65.3kb then read package and done
typed sudo DEBIAN_FRONTEND=noninteractive apt-get install freedombox
says needs to get 102mb of archives i type y enter
does a whole lot of stuff unpacking and preparing etc
setting up freedombox 19.1 and still going.
Now stopped last 9 lines has been processing triggers.
Now this is where i reboot and end up back in Debian.
where do i go from here have been trying for past 15 hours getting tited now.
