A security issue has been discovered in FreedomBox. Any FreedomBox system that has non-administrator users on it is affected.
All currently supported versions are affected:
26.14 in stable-backports/testing/unstable
25.9.3+deb13u1 in stable
23.6.2+deb12u1 in oldstable
A fix is being prepared at this time. In the mean time, if you have non-administrator users, here is a mitigation action that you can take:
In System → Secure Shell Server, disable the option “Allow all users to login remotely”. Then, only users in the “admin” or “freedombox-ssh” groups (or system “sudo” group) will be able to connect through SSH.
The fix is now available in these package versions:
26.15~bpo13+1 in stable-backports
26.15 in testing/unstable
If you have activated Frequent Feature Updates on the Software Update page, then the freedombox package from stable-backports will be installed on the next update. If you have enabled auto-update, then the package should have already been updated by now.
Debian Security team is deciding on how to handle the update for stable and oldstable.
