Freedombox is not updated.
sudo apt update — It does not help
(I get an error with the following message:)
2020-02-01 06:13:04,817 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-01 06:13:04,847 INFO Initial blacklist :
2020-02-01 06:13:04,850 INFO Initial whitelist:
2020-02-01 06:13:04,851 INFO Starting unattended upgrades script
2020-02-01 06:13:04,853 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-01 06:13:25,956 ERROR An error occurred: 404 Not Found [IP: 151.101.112.204 80]
2020-02-01 06:13:25,959 ERROR The URI http://deb.debian.org/debian/pool/main/e/exim4/exim4-base_4.92-8_armhf.deb failed to download, aborting
2020-02-01 12:54:07,830 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-01 12:54:07,860 INFO Initial blacklist :
2020-02-01 12:54:07,862 INFO Initial whitelist:
2020-02-01 12:54:07,863 INFO Starting unattended upgrades script
2020-02-01 12:54:07,865 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-02 06:41:58,246 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-02 06:41:58,274 INFO Initial blacklist :
2020-02-02 06:41:58,277 INFO Initial whitelist:
2020-02-02 06:41:58,278 INFO Starting unattended upgrades script
2020-02-02 06:41:58,279 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-02 06:42:19,414 ERROR An error occurred: 404 Not Found [IP: 151.101.112.204 80]
2020-02-02 06:42:19,417 ERROR The URI http://deb.debian.org/debian/pool/main/e/exim4/exim4-base_4.92-8_armhf.deb failed to download, aborting
2020-02-02 07:38:56,612 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-02 07:38:56,645 INFO Initial blacklist :
2020-02-02 07:38:56,647 INFO Initial whitelist:
2020-02-02 07:38:56,649 INFO Starting unattended upgrades script
2020-02-02 07:38:56,650 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-03 02:59:14,842 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-03 02:59:14,871 INFO Initial blacklist :
2020-02-03 02:59:14,873 INFO Initial whitelist:
2020-02-03 02:59:14,874 INFO Starting unattended upgrades script
2020-02-03 02:59:14,876 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-03 06:35:47,337 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-03 06:35:47,366 INFO Initial blacklist :
2020-02-03 06:35:47,368 INFO Initial whitelist:
2020-02-03 06:35:47,369 INFO Starting unattended upgrades script
2020-02-03 06:35:47,371 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-03 06:36:07,479 ERROR An error occurred: 404 Not Found [IP: 151.101.112.204 80]
2020-02-03 06:36:07,482 ERROR The URI http://deb.debian.org/debian/pool/main/e/exim4/exim4-base_4.92-8_armhf.deb failed to download, aborting
2020-02-04 04:06:05,026 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-04 04:06:05,060 INFO Initial blacklist :
2020-02-04 04:06:05,062 INFO Initial whitelist:
2020-02-04 04:06:05,063 INFO Starting unattended upgrades script
2020-02-04 04:06:05,065 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-04 04:10:37,808 WARNING package libpam-systemd upgradable but fails to be marked for upgrade ()
2020-02-04 04:12:03,520 WARNING package manpages-dev upgradable but fails to be marked for upgrade ()
2020-02-04 04:12:30,505 WARNING package php-wikidiff2 upgradable but fails to be marked for upgrade ()
2020-02-04 04:12:39,785 WARNING package python3-django upgradable but fails to be marked for upgrade ()
2020-02-04 04:12:48,930 WARNING package python3-service-identity upgradable but fails to be marked for upgrade ()
2020-02-04 04:12:59,740 WARNING package slapd upgradable but fails to be marked for upgrade ()
2020-02-04 04:13:09,930 WARNING package systemd upgradable but fails to be marked for upgrade ()
2020-02-04 04:13:18,607 WARNING package systemd-sysv upgradable but fails to be marked for upgrade ()
2020-02-04 04:13:27,530 WARNING package tor upgradable but fails to be marked for upgrade ()
2020-02-04 04:13:36,538 WARNING package tor-geoipdb upgradable but fails to be marked for upgrade ()
2020-02-04 04:13:45,636 WARNING package udev upgradable but fails to be marked for upgrade ()
2020-02-04 06:05:44,548 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-02-04 06:05:44,578 INFO Initial blacklist :
2020-02-04 06:05:44,580 INFO Initial whitelist:
2020-02-04 06:05:44,582 INFO Starting unattended upgrades script
2020-02-04 06:05:44,583 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security, o=Debian Backports,a=buster-backports,l=Debian Backports
2020-02-04 06:10:20,462 WARNING package libpam-systemd upgradable but fails to be marked for upgrade ()
2020-02-04 06:11:47,945 WARNING package manpages-dev upgradable but fails to be marked for upgrade ()
2020-02-04 06:12:16,782 WARNING package php-wikidiff2 upgradable but fails to be marked for upgrade ()
2020-02-04 06:12:26,718 WARNING package python3-django upgradable but fails to be marked for upgrade ()
2020-02-04 06:12:36,516 WARNING package python3-service-identity upgradable but fails to be marked for upgrade ()
2020-02-04 06:12:48,031 WARNING package slapd upgradable but fails to be marked for upgrade ()
2020-02-04 06:12:58,345 WARNING package systemd upgradable but fails to be marked for upgrade ()
2020-02-04 06:13:07,172 WARNING package systemd-sysv upgradable but fails to be marked for upgrade ()
2020-02-04 06:13:16,706 WARNING package tor upgradable but fails to be marked for upgrade ()
2020-02-04 06:13:26,333 WARNING package tor-geoipdb upgradable but fails to be marked for upgrade ()
2020-02-04 06:13:36,069 WARNING package udev upgradable but fails to be marked for upgrade ()
2020-02-04 06:13:52,695 INFO Packages that will be upgraded: apache2 apache2-data apache2-utils
2020-02-04 06:13:52,697 INFO Writing dpkg log to /var/log/unattended-upgrades/unattended-upgrades-dpkg.log
2020-02-04 06:15:00,711 INFO All upgrades installed
- FreedomBox version: 19.1
- Hardware: Raspberry Pi 3B +
