FreedomBox 26.5 released
FreedomBox 26.5 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights of this release:
  • action_utils: Don’t restart web interface when installing an app
  • apache: Use a Uwsgi native socket systemd unit for each app
  • ui: Use inline SVG icons for all apps
  • wireguard: Fix freedombox VPN IP for services
Other changes in this release:
  • action_utils: Stop associated service when stopping a socket unit
  • apache: Increase OpenID Connect RP session timeout activity
  • apache: Minor improvement to getting the request host
  • app: Fix build issue with Django 5.x
  • clients: Fix formatting of package row in table
  • clients: Fix show empty clients in Desktop section
  • clients: Use SVG icons when showing external links
  • container: Add option to skip install
  • container: Fix image extension to .raw for systemd v260
  • doc: Reduce verbosity when building documentation
  • html: Drop trailing slash from void elements
  • html: Drop type attribute value of text/javascript
  • janus: Drop unused reference to font-awesome
  • letsencrypt: Don’t perform operations on apps that are not installed
  • locale: Update translations for German, Russian, Swedish
  • pagekite: Fix issue with adding custom services
  • tests: functional: Drop undefined ‘sso’ pytest mark
  • ui: Add rest of the icons used from fork-awesome set
  • ui: Better placement for dropdown indicator in dropdown button
  • ui: Drop fonts-fork-awesome as dependency
  • ui: Rename ‘plinth_extras’ template tags module to ‘extras’
  • ui: Simplify SVG app icons for using them inline in HTML
  • ui: Use inline SVG icons for buttons, messages, spinners, etc.
  • wireguard: Add button for direct APK download
  • wireguard: Add entries for Homebrew and RPM packages
  • wireguard: Remove client entry for F-Droid which is not available
  • wireguard: Update windows client link
  • Daniel Wiik
  • Ettore Atalan
  • Frederico Gomes
  • James Valleroy
  • Joseph Nuthalapati
  • OwlGale
  • Sunil Mohan Adapa
Due to a severe issue discovered in FreedomBox 26.5, we have followed up with a patch release 26.5.1.
Changes:
  • debian/control: Fix building with nocheck profile
  • debian/copyright: Drop a removed file, correct path for another
  • locale: Update translations for Albanian, Turkish
  • web_server: Fix locating SVG icons on production setup
The following people contributed to this release:
  • Besnik Bleta
  • Burak Yavuz
  • Sunil Mohan Adapa
