FreedomBox 26.4 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights of this release:
- backups: Enable key-based SSH authentication for remote backups
- oidc: New app to implement OpenID Connect Provider
- apache: Implement protecting apps using OpenID Connect
- wireguard: Improve server section user experience flow
Other changes in this release:
- *: Remove some absolute file paths in SVGs
- *: Update URL base from /plinth to /freedombox
- README/HACKING: Update weblate project path to /freedombox
- Vagrantfile: Drop unnecessary sudo configuration for actions
- action_utils: Drop support for link-local IPv6 addresses
- action_utils: Fix issue with type checking a generator
- action_utils: Implement utility to change umask temporarily
- actions, privileged_daemon: Drop some unused global statements
- apache: Fix diagnosing URLs protected by OpenID Connect
- apache: Preserve host header when proxying to service
- backups: Arrange form for adding remote location
- backups: Avoid some repeated text in form help text
- backups: Copy SSH client public key to remote
- backups: Create .ssh folder before creating SSH key
- backups: Create a better comment in the generated SSH key file
- backups: Display SSH public key when adding remote
- backups: Fix issue with Javascript in add remote location form
- backups: Fix showing proper error for incorrect passphrase
- backups: Fix type checking errors
- backups: Generate SSH client key if needed
- backups: Migrate to SSH key auth when mounting
- backups: Minor refactoring
- backups: Show/hide form elements instead of disabling for simplicity
- backups: Simplify handling of migration to SSH keys
- backups: Test adding/removing remote location
- backups: Tweak appearance of add remote location form
- backups: Use SSH key instead of password
- backups: Use selected SSH credential for remote
- backups: tests: Simplify functional test using more classes
- bin: Add tool to change FreedomBox password in Django database
- calibre: Use OpenID Connect instead of pubtkt based SSO
- cfg: Drop unused actions_dir option
- cfg: Drop unused config_dir option
- container: Align terminology in printed banner
- db: Create a utility to get credentials from dbconfig
- debian: Ensure that gbp creates a clean tarball prior to build
- deluge: Use OpenID Connect instead of pubtkt based SSO
- doc/dev: Set new theme for developer documentation
- doc/dev: Use OpenID Connect instead of pubtkt based SSO
- doc/dev: always have an up-to-date copyright year
- ejabberd: Fix setting up certificates for multiple domains
- email: Use OpenID Connect instead of pubtkt based SSO
- featherwiki: Use OpenID Connect instead of pubtkt based SSO
- gitweb: Fix issue with running post init due to missing method
- gitweb: Use OpenID Connect instead of pubtkt based SSO
- js: When page load fails during install, show it to user
- letsencrypt: When copying certificate reset the umask reliably
- locale/bg: Fix several translations with HTML links (Bulgarian)
- locale/de: Fix several translations with HTML links (German)
- locale: Update translations for Albanian, Catalan, Chinese (Simplified Han script), Czech, French, German, Greek, Italian, Swedish, Tamil, Turkish
- matrixsynapse: Update apache config to proxy Synapse client API
- miniflux: Get credentials from dbconfig-common directly
- miniflux: Revert workaround for a packaging bug with DB connection
- mumble: murmurd renamed to mumble-server
- oidc: Style the page for authorizing an OIDC app
- pyproject: Use new format to specify licenses
- quassel: Explicitly set permissions on the domain configuration file
- rssbridge: Use OpenID Connect instead of pubtkt based SSO
- searx: Use OpenID Connect instead of pubtkt based SSO
- sharing: Use OpenID Connect instead of pubtkt based SSO
- sso: Merge into users module, drop pubtkt related code
- syncthing: Use OpenID Connect instead of pubtkt based SSO
- syncthing: tests: Fix tests by allowing rapid restarts
- templates: Allow building pages without navigation bar and footer
- tests: functional: Fix expecting FreedomBox to be home page
- tests: functional: Fix reloading error page during install/uninstall
- tests: functional: Increase systemd rate limits for starting units
- tiddlywiki: Use OpenID Connect instead of pubtkt based SSO
- transmission: Use OpenID Connect instead of pubtkt based SSO
- ui: Add animation for notification dismissal
- ui: Dismiss notifications without page reload
- ui: Refactor notification delete buttons to avoid repeating code
- web_framework: Allow FreedomBox apps to override templates
- web_server: Log requests to WSGI app
- wireguard: Accept/use netmask with IP address for server connection
- wireguard: Fix format when showing multiple endpoints of the server
- wireguard: Fix showing default route setting in server edit form
- wireguard: Fix split tunneling
- wireguard: Show status of default route in server information page
- wireguard: filter .local addresses from showClient view
- wireguard: show server vpn ip in show client page
- wordpress: Use OpenID Connect instead of pubtkt based SSO when private
- Benedek Nagy
- Besnik Bleta
- Burak Yavuz
- Coucouf
- Daniel Wiik
- Dietmar
- Frederico Gomes
- Isak
- James Valleroy
- Jiří Podhorecký
- Joseph Nuthalapati
- kosagi
- Pierfrancesco Passerini
- Sunil Mohan Adapa
- Βασίλης Χατζηκαμάρης
- தமிழ்நேரம்
- 大王叫我来巡山
