FreedomBox 26.12 released
FreedomBox 26.12 has been released and uploaded to Debian unstable.
Typically, the freedombox package will migrate to testing in 2 days, and
then can be uploaded to stable-backports.
Highlights of this release:
* locale: Add Lao translation
* radicale: Redirect from .well-known URLs only temporarily
* wireguard: Fix auto-adding client when no domains are configured
* wireguard: Fix issues with newline in public key when adding client
Other changes in this release:
* *: Additional import path related changes
* *: All other changes need for new import path
* *: Miscellaneous changes to work with reduce the use of term ‘plinth’
* *: Update additional documentation/comments with new import path
* *: Update import path in modules-enabled configuration files
* *: Update imports statements from plinth to freedombox
* bin: Rename main binary from plinth to freedombox
* container: Fix failure with defining a new VM
* d/copyright: Update copyright file
* django: Changes for new import path
* django: Rename DB tables from plinth_ to freedombox_
* doc/dev: Update developer documentation with new import path
* errors: Rename PlinthError to FbxError
* locale: Move lo to freedombox path
* locale: Update translations for Czech, French, Lao, Swedish
* nextcloud: test: Fix functional tests with version 26
* plinth/*: Rename plinth/ folder to freedombox/
* radicale: tests: Don’t fail if Nextcloud is enabled
* tags: tests: Fix functional tests broken by separate apps/add page
* wireguard: Improve reliability functional tests by waiting after ops
  • Bone NI
  • Daniel Nylander
  • James Valleroy
  • Jiří Podhorecký
  • John Doe
  • Sunil Mohan Adapa
Nice update! The WireGuard fixes and the move from plinth to freedombox look especially useful. Great to see continued development and more language support too.
