FreedomBox 25.2 has been released and uploaded to Debian unstable.
Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
gnome: Add app to provide a graphical desktop environment
sogo: Add a new app for SOGo groupware
Other Changes:
action_utils: Implement methods to get/set the systemd boot target
apache: Enable expires module by default
d/control: Fix incorrect comment format
d/copyright: Fix copyright entry for GNOME app icons
db: Add more utilities for managing PostgreSQL databases
email: Make rspamd learn spam/ham when the user marks mails as junk or not junk.
email: Recommend Thunderbird Mobile instead of K-9 Mail
firewall, networks, storage: Drop polkit pkla files
gnome: Add changes missing from branch merge
locale: Updated translations for Albanian, Bulgarian, Chinese (Simplified Han script), Chinese (Traditional Han script), Czech, Dutch, German, Turkish
miniflux: Add management of postgresql daemon in a shared manner
nextcloud: Drop some dead code
nextcloud: tests: functional: Fix test for modified structure of UI
nextcloud: tests: functional: Set override domain testing on VM
ttrss: Add management of postgresql daemon in a shared manner
ttrss: Fix issue with installing after uninstalling
ui: Drop the temporary fix for missing popper.js 2.0
ui: Fix missing arrow on dropdown form fields
ui: Fix tag separator not showing on some machines
wordpress: Order daemon enable/disable correctly
Do you suppose that is going to change episodes of high disk load? Hoping so, I know there is another issue open for that. Sometimes postgres is active when I hear the grinding.
Oh amazing ok good to know! Ok to run them at the same time? Would there be any issues with that?
Only one of apps will be automatically discovered by Desktop applications using the /.well-known/ URLs. Right now, the priority is also not well defined. Other than that, there should be no issue with running multiple calendar applications.
