FreedomBox 25.11 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights of this release:
- email: Fix Thunderbird auto configuration failure
- matrixsynapse, upgrades: Install select packages from unstable
Other Changes:
- action_utils: Implement a utility to run a command as different user
- actions, backup: Implement raw output for privileged daemon
- actions, backups: Fix tests depending on sudo based actions
- actions: Drop feature to run privileged action as another user
- actions: Drop sudo based privileged actions
- actions: Framework for capturing stdout/stderr in privileged daemon
- actions: Simplify raw output code in privileged methods
- backups: Trim translatable string
- container: Add support for Trixie as stable distribution
- container: Pass --nvram option to virsh undefine
- d/control: Remove libpam-abl as a recommendation
- diagnostics: Fix notification severity when skipping tests
- dynamicdns: Handle showing errors from GnuDIP
- gitweb: Don’t use privileged action feature to run as different user
- gitweb: Use pathlib API more
- HACKING.md: Mention using virtual machines instead of containers
- homeassistant: Fix typo in description
- l10n: Fix a broken string in Russian translation
- l10n: Fix broken Italian translation
- l10n: Fix formatted strings for errors/exceptions
- locale: Update translations for Bulgarian, Chinese (Simplified Han script), Czech, Dutch, French, German, Italian, Russian, Turkish, Ukrainian
- Makefile, settings: Use full paths in pot files
- package: Don’t consider uninstalled packages as available
- package: Refresh apt cache if sources list is newer
- power: logind config to ignore laptop lid close
- privileged: Don’t isolate /var/tmp/ for privileged daemon
- privileged_daemon: Introduce a command line client for the API
- privileged_daemon: Log only to journal and not console
- samba: Update client list
- storage: Don’t use privileged action feature to run as different user
- syncthing: Update Android clients to Syncthing-Fork
- tests: functional: Fix incorrect skipping of install tests
- ui: Fix missing semicolon in JS file
- upgrades: Don’t allow needs-restart to restart privileged daemon
- upgrades: Overhaul detection of distribution
- web_server: Restart in development mode only for source code changes
- 109247019824
- Burak Yavuz
- Coucouf
- Dietmar
- ikmaak
- James Valleroy
- Jiří Podhorecký
- Joseph Nuthalapati
- Roman Akimov
- Sunil Mohan Adapa
- Veiko Aasa
- Максим Горпиніч
- 大王叫我来巡山
