FreedomBox 25.1 released
FreedomBox 25.1 has been released and uploaded to Debian unstable.
Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
  • email: Show DNS entries for all domains instead of just primary
  • privacy: Add option in UI to set lookup URL for public IPs
Other Changes:
  • app: Add tags to menu and frontpage components
  • app: Allow apps to instantiate without Django initialization
  • app: Stop showing short description on installation page
  • apps: Only show app tags all the tags in apps page search box
  • backups: Add warning that services may become unavailable
  • backups: Handle error when there is not enough space on disk
  • backups: Make all generated archive names consistent
  • backups: Properly cleanup after downloading an archive
  • deluge: tests: functional: Fix deluge client logged in detection
  • doc: dev: Remove short description and add tags to all components
  • dynamicdns: Use the public IP lookup URL from privacy app
  • email: Create DKIM keys for all known domains
  • email: Fix regression error when installing/operation app
  • email: Show reverse DNS entries to be configured
  • locale: Translated using Weblate (German, Russian)
  • miniflux: Ignore an type check error with pexpect library
  • privacy: Introduce utility to lookup external IP address
  • privacy: Show notification for privacy settings again
  • ui: Don’t place JS file at the bottom of the page
  • ui: Drop remnants of already removed background images
  • ui: Fix missing variables in Bootstrap 5.2/Debian stable
  • ui: Update section header style to increase size, remove underline
  • ui: js: Load all JS files in deferred mode to speed up page load
  • views: Use tags from menu or shortcut instead of the app
  • web_framework: Disable caching templates files in development mode
  • Benedek Nagy
  • Dietmar
  • gfbdrgng
  • James Valleroy
  • Sunil Mohan Adapa
  • Veiko Aasa
