FreedomBox 24.9 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Changes in this release:
- action_utils, nextcloud: Make podman util more generic
- config: Handle dropin config files with limited permissions
- locale: Update translations for Albanian, Chinese (Simplified), Chinese (Traditional), Russian, Spanish, Turkish
- nextcloud: (Note that this app is currently disabled, and not available to install.)
- Add network interface to firewall zone after creating it
- Add warning that the app is experimental
- Allow backup/restore when app is disabled
- Connect to mysql using socket instead of TCP
- Connect to redis using Unix socket
- Connect to slapd for LDAP using Unix socket
- Don’t fail uninstall if DB or user do not exist
- Don’t set password on redis server
- Don’t show incorrect phone region when it is not set
- Drop a repeated creation of systemd service file
- Ensure that database is running when running setup
- Expand on the warning about container usage
- Fail on errors when configuring the app
- Fix configuring trusted proxies setting
- Improve check used to test if installation wizard is done
- Improve database permission granting
- Improve setting up LDAP configuration
- Minor changes to cron timer units
- Minor refactoring
- Minor update to description regarding users’ usage
- Refactor container creation code
- Refactor setting admin password
- Remove fail2ban jail, brute force protection present
- Rename the systemd service names
- Retrieve database password in a more robust way
- Use a separate DB for redis
- Use secrets module generate passwords
- When backup fails, unset the maintenance mode
- tests: functional: Disable functional tests
- Besnik Bleta
- Burak Yavuz
- gallegonovato
- James Valleroy
- Joseph Nuthalapati
- Ray Kuo
- Sunil Mohan Adapa
- Yurt Page
- 大王叫我来巡山
