FreedomBox 24.6 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
- gitweb: Fix modifying git repositories when gitweb app is disabled
- users: Fix creating users with initial set of groups
- wordpress:
- Don’t fail setup if mysql installed but not running
- Drop database user when app is uninstalled
- Fix backup, restore and uninstall when db is not running
- zoph:
- Don’t fail with backup/restore if app is disabled
- Don’t redirect to setup page when app is disabled
- Ensure that database server is running when setting up app
- Hide configuration form when app is disabled
- Restore database password to old value after restore operation
- Uninstall fully so that reinstall works
Other changes:
- *: Add type hints for app init methods
- *: Add type hints for diagnose method
- action_utils: Implement method for starting a service temporarily
- actions: Fix log message when action return can’t be decoded
- actions: When action errors out, log a better message
- app: Add ability to hide configuration form when app is disabled
- app: views: Expose method to get enabled/disabled state and cache it
- daemon: Added method to ensure a daemon is running in component
- diagnostics: Add tests for get_results
- diagnostics: Handle TypeError when copying results
- locale: Update translations for Dutch
- log: Don’t log with in color inside actions scripts
- samba: Ignore non-existent users who are in freedombox-share group
- tests: functional: Refactor install/setup fixture for apps
- tests: functional: Uninstall app after backup and before restore
- users: Minor refactor when creating django groups
- users: tests: Do not remove LDAP user when testing views
- wordpress: Fix minor issue in restoring database
- wordpress: tests: Uninstall app after backup and before restore
- ikmaak
- James Valleroy
- Sunil Mohan Adapa
- Veiko Aasa
