FreedomBox 24.25 has been released and uploaded to Debian unstable.
Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
- deluge: Fix app installation on Debian testing
 - notifications: Don’t error when dismissing missing notifications
 - ui: Switch to using bootstrap 5
Other Changes:
- action_utils: Add utility to ensure that service is stopped
 - apache: Relax content security policy to allow data: URL
 - ci: Add flake8 to gitlabci container
 - d/control: Drop unnecessary recommendations
 - d/control: Drop version specification on dependencies for Bookworm
 - debian: Added po-debconf Catalan translation
 - deluge: Cleanup and simplify setup code
 - diagnostics: Fix trimming an i18n string
 - diagnostics: tests: functional: Pick errors more specifically
 - firewalld: Reduce severity for alert about service on internal zone
 - help: Add a class to the help index page
 - help: Update the privacy notice on status log page
 - i2p: Drop app as it has not been available in Debian for a while
 - letsencrypt: Declare explicit dependency on openssl
 - locale: Update translations for Albanian, Bulgarian, Chinese (Simplified Han script), Czech, French, German, Russian, Turkish
 - matrixsynapse: Fix trimming an i18n string
 - networks: Fix issue with loading create PPPoE form
 - networks: Fix minor typo in template related to signal strength
 - networks: Use new accordion component from Bootstrap 5
 - openvpn: Declare explicit dependency on openssl
 - power: Refactor display of package manager busy alerts
 - radicale: Update link to supported clients
 - sso: Switch using cryptography module instead of OpenSSL.crypto
 - tags: Fix issue with JS init on a page without tags
 - tags: tests: Fix deprecated webdriver attribute
 - tests: functional: Disable smooth scrolling from Bootstrap 5
 - tests: functional: Don’t try disable app after tests if app was not installed
 - tests: functional: Fix app installation test skipped on slow machines
 - ui: Accept default styling of Bootstrap 5 for warning button
 - ui: Align app icons in the center for home, apps, and help pages
 - ui: Allow underlining for most links due to Bootstrap 5
 - ui: Allow users to provide a CSS file to customize styling
 - ui: Cleanup use of colors with CSS variables
 - ui: Don’t use nav-link inside card
 - ui: Drop use of badge-* utility classes for newer replacements
 - ui: Fix flash of notifications popdown during page load
 - ui: Fix issue with notifications icon showing twice in mobile view
 - ui: Fix overflow of exception text in message
 - ui: Fix placement of tags menu under tags input with Bootstrap 5
 - ui: Fix styling in dismiss button in form errors for Bootstrap 5
 - ui: Fix toggle button styling for Bootstrap 5
 - ui: Reduce the gap at the top of the pages
 - ui: Rename data- attributes to data-bs- for Bootstrap 5
 - ui: Restore spacing between form elements in Bootstrap 5
 - ui: Restyle tags, remove underlining of text
 - ui: Show disabled form elements as grey for Bootstrap 5
 - ui: Style the ‘Log out’ item properly
 - ui: Update custom button styles for Bootstrap 5
 - ui: Update styling for navbar menu items
 - ui: Use Bootstrap 5 styling for all alerts
 - ui: Use collapse instead of dropdown for notification in Bootstrap 5
 - ui: Workaround dropdowns not working with Bootstrap 5
 - ui: app, system: Revert to earlier width for card lists
 - ui: app: Fix an incorrect HTML tag nesting
 - ui: backups: Drop unused styling in verify host key page
 - ui: backups: Use Bootstrap color variables instead of static values
 - ui: diagnostics: Fix gap between headings
 - ui: diagnostics: Fix layout of repair buttons
 - ui: firewall: Fix styling with Bootstrap 5
 - ui: forms: Fix margins for form labels for Bootstrap 5
 - ui: help: Fix alignment issue with footer links in about page
 - ui: samba: Fix layout regressions with Bootstrap 5
 - ui: snapshots: Fix horizontal form layout on mobiles for Bootstrap 5
 - ui: snapshots: Fix horizontal form styling margins for Bootstrap 5
 - ui: users: Fix close button for confirmation dialog for Bootstrap 5
- 109247019824
 - Besnik Bleta
 - Burak Yavuz
 - Carles Pina i Estany
 - Ettore Atalan
 - gfbdrgng
 - James Valleroy
 - Jiří Podhorecký
 - John Doe
 - Paul Lettich
 - Sunil Mohan Adapa
 - Veiko Aasa
 - 大王叫我来巡山
