FreedomBox 24.21 released
FreedomBox 24.21 has been released and uploaded to Debian unstable.
Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights of this release:
  • django: Improve handling of file uploads
  • nextcloud: Fix existing installs to upgrade properly
Other changes:
  • action_utils: Fix missing parent folder when creating apt hold flag
  • action_utils: Introduce utility to move uploaded files
  • actions: Handle exceptions with Path-like objects
  • featherwiki: Use new utility for handling uploads
  • functional tests: Upgrade dependencies selenium and splinter
  • kiwix: Don’t leave invalid .zim in library after a failed attempt
  • kiwix: Use new utility for handling uploads
  • locale: Albanian: Fix build issue by correcting typo
  • locale: Update translations for Albanian, Czech
  • names: Don’t control resolved daemon when package is not installed
  • names: Don’t hard depend on systemd-resolved
  • names: Don’t show resolver status if package is not installed
  • names: Introduce method to check if resolved is installed
  • names: Perform resolve diagnostics only if resolved is installed
  • names: Schedule a task to install systemd-resolved when possible
  • names: Try to install systemd-resolved during app setup
  • networks: Disable DNS-over-TLS option if resolved is not installed
  • networks: Don’t show DNS-over-TLS when resolved is not installed
  • nextcloud: During upgrade wait properly for upgrade to complete
  • privacy: Disable DNS fallback option if resolved is not installed
  • samba: Remove option to backup app
  • storage: Skip tests that involve loopback device in a container
  • tiddlywiki: Avoid writing duplicate temporary files
  • transmission: tests: Fix functional test failures in Debian testing
  • Benedek Nagy
  • Besnik Bleta
  • James Valleroy
  • Jiří Podhorecký
  • Joseph Nuthalapati
  • Sunil Mohan Adapa
  • Veiko Aasa
