FreedomBox 24.17 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
- featherwiki: Add new app for Personal Notebooks
- tiddlywiki: Add new app for Non-linear Notebooks
Other Changes:
- COPYING.md: Update copyright years
- actions: Add error when likely parameters are not marked as secret
- actions: Define and allow a new alias for str; secret_str
- actions: Log arguments without secret strings in privileged calls
- apache: Enable dav and dav_fs modules
- backups: Mark secret strings in privileged actions
- base.html: Drop dependency on modernizr.js library
- bepasty: Mark secret strings in privileged actions
- django: settings: Don’t set USE_L10N on newer versions
- featherwiki: Fix a type check failure
- featherwiki: Proxy download through
freedombox.org - firewall: Setup inter-zone forwarding
- gitweb: Don’t backup/restore a drop-in configuration file
- ikiwiki: Mark secret strings in privileged actions
- locale: Update translations for Albanian, Bulgarian, Chinese (Simplified), Czech, Spanish, Turkish
- makefile: Don’t fail while building and installing multiple versions
- mediawiki: Mark secret strings in privileged actions
- miniflux: Mark secret strings in privileged actions
- mumble: Mark secret strings in privileged actions
- nextcloud: Mark secret strings in privileged actions
- nextcloud: Prevent process restart when nextcloud is uninstalled
- nextcloud: Redirect to URL nextcloud/ if ending slash is not given
- nextcloud: tests: functional: Add base and interface tests
- pagekite: Mark secret strings in privileged actions
- rssbridge: tests: Add missing
__init__.py - shadowsocks: Mark secret strings in privileged actions
- shadowsocksserver: Mark secret strings in privileged actions
- ssh: Mark secret strings in privileged actions
- storage: Add diagnostic for grub config issue
- templates: Fix warning about using default.html for form template
- tests: functional: Allow submitting form buttons along with inputs
- tests: functional: Name the background fixture
- users: Mark secret strings in privileged actions
- 109247019824
- Besnik Bleta
- Burak Yavuz
- gallegonovato
- James Valleroy
- Jiří Podhorecký
- Joseph Nuthalapati
- Sunil Mohan Adapa
- 大王叫我来巡山
