FreedomBox 24.10 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
- nextcloud: Enable app with experimental warning
- minidlna: Add media directory selection form
Other Changes:
- app, component: Add repair method
- diagnostics: Add optional component_id to DiagnosticCheck
- diagnostics: Change “Re-run setup” to “Try to repair”
- letsencrypt: Re-obtain certificates during repair
- letsencrypt: Remove unused imports
- locale: Update translations for Chinese (Simplified), Chinese (Traditional), Czech, Spanish, Turkish
- minidlna: Do not proxy minidlna web interface over Apache
- minidlna: Explicitly include ssdp service to firewall configuration
- minidlna: Restart app when upgrading to reconfigure firewall
- nextcloud: Add fallback for when quadlet is not available
- nextcloud: Allow re-running setup
- nextcloud: Allow re-running setup when app is disabled
- nextcloud: Create network using systemd generator
- nextcloud: Drop network namespacing in container, use host network
- nextcloud: Enable pretty URLs without /index.php in them
- nextcloud: Implement enable/disable container
- nextcloud: Populated and maintain a list of trusted domains
- nextcloud: Pull the image separately before starting systemd unit
- nextcloud: Restart container when dependent services are restarted
- nextcloud: Ship instead of create cron timer related units
- nextcloud: Use php-fpm container instead of apache container
- nextcloud: Use systemd generator for creating container service
- nextcloud: Wait on init sync lock
- nextcloud: Warn that community provides the container not team
- notification: Handle more formatting errors
- setup: Add method to run app repair
- storage: Add an option to include help text to directory selection form
- Burak Yavuz
- gallegonovato
- James Valleroy
- Jiří Podhorecký
- Ray Kuo
- Sunil Mohan Adapa
- Veiko Aasa
- 大王叫我来巡山
