FreedomBox 23.9 has been released and uploaded to Debian experimental. These changes will not be available to most FreedomBox users until after Debian Bookworm is released.
Highlights:
- transmission: Allow remote UIs to connect
- ttrss: Allow apps to use /tt-rss URL instead of separate one
Other Changes:
- apache: Reload apache using component if config changes
- debian: Follows policy v4.6.2
- debian: Update copyright years
- doc/dev: Update copyright year
- help: Add information on obtaining source code
- locale: Update translations for Japanese
- mediawiki: Make a utility method public
- mediawiki: Make retrieving list of supported languages robust
- mediawiki: Simplify retrieving the default language
- minidlna: Resize icon and export to PNG also
- service: Remove reference to managed_services in a message
- storage: Handle mount error properly
- theme: Move icons to app folders
- tor: Check if Hidden service is version 3
- tor: Only diagnose relay ports if feature enabled
- tor: Rename Hidden service to Onion service
- transmission: Add Tremotesf to list of client apps
- ttrss: Don’t show app in enabled list of apps if install fails
- ttrss: Update list of clients
- ttrss: Use the apache component to restart apache on config change
- uninstall: Fix issue with uninstall of apps that have no backup
- zoph: Don’t fail at showing app view during uninstall
- James Valleroy
- nbenedek
- Nobuhiro Iwamatsu
- Sunil Mohan Adapa
