FreedomBox 23.8 has been released and uploaded to Debian experimental. These changes will not be available to most FreedomBox users until after Debian Bookworm is released.
Highlights
- coturn: Prevent package removal when roundcube is uninstalled
- datetime: Re-implement backup/restore for timezone
- gitweb: Disable snapshot feature
Other Changes
- HACKING: Force pip to install packages to system environment
- bepasty: When uninstalling, remove all data and configuration
- calibre: Remove libraries during uninstallation
- ci: Force pip install for functional tests
- coturn: When uninstalling, remove all data and configuration
- datetime: Use unique component ID for related daemon
- deluge: When uninstalling, remove all data and configuration
- gitweb: When uninstalling, remove all data and configuration, remove repositories
- gitweb: Make globally configured features overridable per-repository
- gitweb: Simplify handling shortcut for front page
- ikiwiki: When uninstalling, remove all data and configuration
- infinoted: When uninstalling, remove all data and configuration
- locale: Update translations for Bulgarian, French, Ukrainian
- matrixsynapse: When uninstalling, remove all data and configuration
- mediawiki: When uninstalling, remove all data and configuration
- mediawiki: Fix broken view on Bullseye due to language selection
- openvpn: When uninstalling, remove all data and configuration
- roundcube: When uninstalling, remove all data and configuration
- rssbridge: When uninstalling, remove all data and configuration
- samba: When uninstalling, remove all data and configuration
- searx: When uninstalling, remove all data and configuration
- searx: Simplify handling shortcut for front page
- shaarli: When uninstalling, remove all data and configuration
- shadowsocks: When uninstalling, remove all data and configuration
- sharing: When uninstalling, remove all data and configuration
- syncthing: When uninstalling, remove all data and configuration
- syncthing: Remove unused pathlib import so job code-quality can pass
- tests: Don’t error during collection if selenium is not installed
- tests: functional: Make install script work for Bullseye
- tests: functional: Remove handling for custom enable/disable buttons
- tests: functional: Update detecting page changes
- tor: When uninstalling, remove all data and configuration
- ttrss: When uninstalling, remove all data and configuration
- upgrades: Check apt result during dist-upgrade
- wordpress: When uninstalling, remove all data and configuration
- 109247019824
- Coucouf
- Ihor Hordiichuk
- James Valleroy
- nbenedek
- Sunil Mohan Adapa
- Veiko Aasa
