FreedomBox 23.3 released
FreedomBox 23.3 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Changes:
  • config: Fix showing the value of the default home page
  • email: Revert workaround for error on finishing uninstall
  • firewalld: Allow upgrade to version 2*
  • gitweb: tests: Skip tests using git when git is not installed
  • locale: Update translations for Bulgarian
  • tests: functional: Fix submitting forms with notifications present
  • tor: Also use Aptsources822 augeas lens
  • tor: Remove workaround for old Augeas bug
  • upgrades: Add augeas lens for Deb822 apt sources
  • views: Use dedicated view when showing an app with operations
  • 109247019824
  • James Valleroy
  • Sunil Mohan Adapa
