FreedomBox 23.16 has been released and uploaded to Debian unstable. Typically, the freedombox package will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights:
- openvpn: Renew server/client certificates
- openvpn: Correctly set expiry of server/client certs to 10 years
Other Changes:
- backups: Remove use of length_is template function
- django: Remove use of X-XSS-Protection header
- locale: Update translations for Czech, Norwegian Bokmål, Swedish
- networks, samba: Fix tests setting firewall zone
- openvpn: Ensure that re-running setup works as expected
- openvpn: Fix app not installing on Debian testing
- openvpn: Minor refactoring in setting up easy-rsa
- openvpn: Use config file instead of env vars for easy-rsa
- sso: Switch to django-axes >= 5.0
- sso: Use POST method for logout
- users, networks: Use the autofocus HTML attribute sparingly
- James Valleroy
- Jiří Podhorecký
- Joseph Nuthalapati
- Michael Breidenbach
- Petter Reinholdtsen
- Sunil Mohan Adapa
