FreedomBox 23.11 has been released and uploaded to Debian experimental.
These changes will not be available to most FreedomBox users until after Debian Bookworm is released (June 10).
Highlights
- *: Fix icons not present in the generated .deb
- shadowsocksserver: Add separate app for Shadowsocks server
Other Changes
- apache: Fix failure during app update
- apache: Use drop-in config component for /etc files
- bepasty: Use drop-in config component for /etc files
- calibre: Use drop-in config component for /etc files
- cockpit: Use drop-in config component for /etc files
- config: Add new component for managing drop-in /etc/ config files
- debian/install: Add new place in /usr to keep drop-in config files
- deluge: Use drop-in config component for /etc files
- ejabberd: Use drop-in config component for /etc files
- email: Use drop-in config component for /etc files
- gitweb: Use drop-in config component for /etc files
- i2p: Use drop-in config component for /etc files
- ikiwiki: Use drop-in config component for /etc files
- janus: Use drop-in config component for /etc files
- letsencrypt: Use drop-in config component for /etc files
- matrixsynapse: Use drop-in config component for /etc files
- mediawiki: Use drop-in config component for /etc files
- minidlna: Use drop-in config component for /etc files
- networks: Use drop-in config component for /etc files
- pagekite: Drop the config file for forcing use of Debian certs
- privacy: Use drop-in config component for /etc files
- radicale: Use drop-in config component for /etc files
- roundcube: Use drop-in config component for /etc files
- rssbridge: Use drop-in config component for /etc files
- searx: Use drop-in config component for /etc files
- security: Use drop-in config component for /etc files
- sharing: Use drop-in config component for /etc files
- ssh: Use drop-in config component for /etc files
- sso: Use drop-in config component for /etc files
- syncthing: Use drop-in config component for /etc files
- transmission: Use drop-in config component for /etc files
- ttrss: Use drop-in config component for /etc files
- upgrades: Use drop-in config component for /etc files
- users: Use drop-in config component for /etc files
- wordpress: Use drop-in config component for /etc files
- James Valleroy
- Sunil Mohan Adapa
