FreedomBox 22.18 has been released and uploaded to Debian unstable.
Migration to testing is temporarily on hold due to a bug in another package: https://bugs.debian.org/989409
Highlights
- networks: Remove DNSSEC diagnostics
- setup: Allow starting installation when package manager is busy
- setup: Fix issue with immediate refresh after installation
Other Changes
- *: Add setup method on all apps that don’t have it
- *: Drop module level app property
- *: Make force upgrading part of app rather than a module
- *: Make setup method part of App class for all apps
- app: Drop optimization that skips setup process
- backups: tests: Mark need for Django database during API tests
- container: Add IdentitiesOnly option to SSH
- container: Ignore flake8 error ‘line too long’ in bash script text
- coturn: Fix link to ejabberd in description
- doc: dev: Document previously undocumented components
- ejabberd: Fix showing the status messages
- locale: Update translations for Bulgarian, Czech, Dutch, French, German, Turkish, Ukrainian
- matrixsynapse: Fix showing the status messages
- notification: Pass full context when rendering body template
- operation: Add module to manage threaded operations
- package: Run installation operation using app_id instead of module
- setup: Drop setup_helper and use the new Operation API
- sharing: Add installing and enable/disable like other apps
- sharing: tests: functional: Fix a flaky test by waiting
- ssh: tests: functional: Keep service enabled after tests
- storage: Fix enumerating partitions without mount points
- 109247019824
- Andrij Mizyk
- Burak Yavuz
- Cosmin Humeniuc
- ikmaak
- James Valleroy
- Jiří Podhorecký
- Maxime Leroy
- nautilusx
- Sunil Mohan Adapa
- Veiko Aasa
