FreedomBox 22.15 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- backups: Add options to keep sshfs shares responsive
- backups: Unmount repositories before and after backup
- users: create home directories for newly created users
Other Changes
- *: pylint: Avoid calling super() with arguments
- *: pylint: Don’t inherit from ‘object’
- *: pylint: Drop unnecessary ‘pass’ statements
- *: pylint: Explicitly specify encoding when open a file
- *: pylint: Suppress unused argument warnings
- ci: Use compatible versions of Selenium and Splinter
- locale: Update translations for Bulgarian, Russian, Ukrainian
- mediawiki: Add regex validator to the domain field
- mediawiki: Remove Buster specific code not needed in Bullseye
- mediawiki: Remove wgLogo as it is not needed in Bullseye
- pyproject.toml: Ignore some refactoring messages with pylint
- static: js: css: Make multiple select fields work with Django 4.0
- tests: functional: Simplify GitLabCI configuration
- upgrades: Hold packages one at a time
- upgrades: Re-add workaround for grub
- views: Add a comment about change in Django 4.0
- 109247019824
- Andrij Mizyk
- Artem
- Guillermo Lopez Alejos
- James Valleroy
- Joseph Nuthalapati
- nbenedek
- Nikita Epifanov
- Sunil Mohan Adapa
