FreedomBox 21.15 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- dynamicdns: Update URLs to the new dynamic DNS server
- firewall: Allow configuration upgrade to version 1.0.x
- shaarli: Enable app (only available in testing and unstable)
Other Changes
- *: Drop module level depends declaration
- *: Drop module level package_conflicts and use component API
- *: Drop unused manual_page at module level
- *: Drop use of managed_packages and rely on Packages component
- *: Drop use of managed_services, rely on Daemon component
- *: Drop use of module level is_essential flag
- *: Drop use of module level version
- *: Drop use of unnecessary managed_paths
- *: Use the App’s state management API
- actions/letsencrypt: Drop use of managed_paths and use LE component
- actions/service: Drop unused list action
- actions/service: Drop use of managed_services for Daemon component
- actions: Get list of packages from Packages components
- app: Introduce API for managing setup state of the app
- app: Introduce API to setup an app
- bind: Drop alias handling unnecessary in >= Bullseye
- daemon: Add new component to hold information about related daemons
- doc/dev: Drop discussion on managed_paths
- doc/dev: Drop reference to module level depends declaration
- doc/dev: Remove mention of managed_services
- doc/dev: Remove outdated reference to init() at module level
- doc/dev: Update documentation to not refer to managed_packages
- email_server: Merge domain configuration with app view
- email_server: Simplify domain configuration form
- first_boot: Drop use of loaded_modules and use App.list
- forms: Fix regression with TLS domain form in quassel and tt-rss
- letsencrypt: On domain removal, don’t revoke certificate, keep it
- locale: Update translations for Czech, German, Norwegian Bokmål
- main: List apps instead of modules
- middleware, views: Reduce use of setup_helper
- module_loader, app: Move app init to app module
- package: Add parameter to specify skipping package recommendations
- package: Implement installing packages in the component
- package: Introduce component API for package conflicts
- packages: Move checking for unavailable packages to component
- security: Drop use of loaded_modules and use App.list
- security: Drop use of managed_services in security report
- security: Get the list of packages from Packages component
- setup: Drop unused API for app’s state management
- setup: List dependencies for apps instead of modules
- setup: Run setup on apps instead of modules
- setup: Use apps instead of modules to determine running first setup
- setup: Work on apps instead of modules for force upgrade
- tests: Add ‘domain’ mark for apps that add/remove domains
- web_server: Drop use of loaded_modules and use App.list
- James Valleroy
- Johannes Keyser
- Petter Reinholdtsen
- Sunil Mohan Adapa
- trendspotter
