FreedomBox 21.11 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- ttrss: Fix daemon not running sometimes on startup
Other Changes
- *: Always pass check= argument to subprocess.run()
- *: Convert all functional tests to python format
- *: Move all systemd service files from /lib to /usr
- calibre: Run service only if when installed
- d/control: Allow building with python interpreter of any arch
- d/rules: Don’t install and enable other systemd service files
- d/rules: Don’t use setup.py to invoke tests, invoke directly instead
- email: Manage known installation conflicts
- locale: Update translation for Bulgarian, Ukrainian
- package: Add functions for removing packages
- performance: Cleanup code meant for cockpit version < 235
- pyproject.toml: Merge contents of .converagerc
- pyproject.toml: Merge contents of pytest.ini
- settings: Choose password hashing complexity suitable for SBCs
- setup: Show and remove conflicts before installation
- sso, translation: Help set language cookie when user logins in
- storage: tests: functional: Fix tests always getting skipped
- tests: Add some missed marks for functional tests
- tests: Add tests for action utilities
- tests: Improve handling of tests skipped by default
- tests: help: Add help view tests
- translation: Always set language cookie when switching language
- ttrss: Add systemd security hardening to daemon
- ttrss: tests: functional: Make subscription faster
- user: Accommodate Django 3.1 change for model choice iteration
- users: Help set language cookie when user profile is edited
- wordpress: Run service only if when installed and configured
- 109247019824
- Andrij Mizyk
- Fioddor Superconcentrado
- James Valleroy
- Joseph Nuthalapati
- Sunil Mohan Adapa
