FreedomBox 21.10 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- locale: Update translations for German, Italian, Swedish, Turkish, Ukrainian
Other Changes
- Use Django gettext functions instead of ugettext
- Use allow/denylist instead white/blacklist in comments
- Use django.urls.re_path() instead of its alias url()
- Various isort fixes
- pyproject: Make isort consistent across execution environments
- settings: Set Django auto field type explicitly
- signals: Drop provider args when creating Signal object
- sso: Update usage of OpenSSL crypt signing API
- tests: Convert functional tests to python format
- tests: Introduce fixtures to make it easy to test actions
- tests: Show warning when app not available
- tests: Use common fixtures for testing actions module
- tests: Use newer splinter API for finding links
- views: Update utility for checking URL safety
- Andrij Mizyk
- Burak Yavuz
- Dietmar
- James Valleroy
- Johannes Keyser
- Michael Breidenbach
- Sunil Mohan Adapa
- Veiko Aasa
