FreedomBox 21.0 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- apache2: Allow downloads in openvpn and backups with latest browsers
Other Changes
- locale: Update translations for Dutch, French, German, Hungarian, Polish, Spanish, Swedish, Turkish
- app: Add locked flag
- app: component: Add app_id and app properties
- app: info: Move client validation to info component
- backups: Add new component for backup and restore
- backups: Don’t open a new window for downloading backups
- dev-container: ‘up’ command: Show banner also when container is already running
- dev-container: Add command to print container IP address
- dev-container: Add subcommand to run tests
- doc: dev: Update the tutorial to reflect latest API/code
- ejabberd: functional tests: Wait until the jsxc buddy list is loaded
- functional tests: Make tests compatible with pytest-bdd v4.0
- functional-tests: Fix installation errors in install.sh script
- gitweb: Add functional tests for git-access group
- gitweb: tests: functional: Fix test failures in localized environment
- mumble: Updated mumla and removed plumble from clients list
- openvpn: Don’t show running status on download profile button
- plinth: Fix daemon is enabled check when service alias is provided
- radicale: Fix backup and restore of configuration
- tests: functional: Improve creating users in tests
- transmission: Show port forwarding information
- transmission: Update description
- upgrades: Add service for dist upgrade
- upgrades: Ensure freedombox package is upgraded during dist upgrade
- upgrades: Hold tt-rss during dist upgrade, if available
- upgrades: Install python3-systemd for unattended-upgrades
- upgrades: Restart FreedomBox service at end of dist-upgrade
- upgrades: Use full path to searx action script
- users: Skip action script tests if LDAP is not set up
- Burak Yavuz
- Dietmar
- Doma Gergő
- ikmaak
- James Valleroy
- Johannes Keyser
- Joseph Nuthalapati
- Michael Breidenbach
- Stanisław Stefan Krukowski
- Sunil Mohan Adapa
- ullli
- Veiko Aasa
