FreedomBox 20.8 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights of this release:
syncthing: Add service to freedombox-share group
users: When adding service to sharing group, only restart if already running
datetime: Ignore time synchronization service in containers and virtual machines
minidlna: Make app installable inside unprivileged container
web_server: Suppress warnings that static directories don’t exist
debian: Remove unused timer
static: Use SVG logo during first wizard welcome step
static: Reduce the size of the background noise image
setup.py: Don’t install/ship .po files
static: Don’t ship visual design file and unused images
all: Update links to repository and project page
coturn: Add app to manage Coturn TURN/STUN server
mediawiki: Partial fix for installing on testing
datetime: Disable diagnostics when no tests are available
data: Print hostname and IP addresses before console login
snapshot: Fix message when not available
snapshot: Fix title
mumble: Add Mumla to the list of clients
locale: Update translations for Spanish, Telugu, Russian, German, French, and Swedish
Were there any changes to how (wireless) networks work? Yesterday my home router automatically upgraded from 20.7 to 20.8, rebooted the OS and now my home WiFi doesn’t work anymore. I can connect to the WiFi network, but routing doesn’t work. For example, I can’t even ping from my laptop the FreedomBox router, even though the router assigned an IP address to the laptop.
Thank you, @fred1m! This did it, but it looks like a one-time solution. As soon as I restart the OS, the problem reappears. It would be great if there was a permanent solution.
COTURN ERRORS on Raspberry Pi3B+, Rasbian Buster, and Freedombox 20.8
FYI@Sunil, I just updated to 20.8 and interested to try COTURN. However I get two error messages.
UPDATE REGARDING SECOND ERROR MESSAGE
So I have just got to reboot Freedombox to get rid of the COTURN install error, as mentioned already here: Building/configuring a TURN server - #38 by sunil (this didn’t come up when I searched!). Thanks
FIRST ERROR MESSAGE
The first when clicking on the: Learn more… link on the COTURN install page, I get taken to: MY-DOMAIN/plinth/help/manual/-/Coturn and shown the following 404 page not found error:
404
Requested page /plinth/help/manual/en/Coturn was not found.
If you believe this missing page should exist, please file a bug at the FreedomBox Service (Plinth) project issue tracker.
And the second when clicking install to install COTURN I get the error message:
I have now added a wiki page for Coturn. Should appear in today’s release 20.9 (reaches users by end of the week). Manual page can read from wiki meanwhile…
Reboot is a workaround for this issue. This is also fixed in the upcoming release.
