FreedomBox 20.14 has been released and uploaded to Debian unstable. Typically, it will migrate to testing in 2 days, and then can be uploaded to stable-backports.
Highlights
- apache: Disable mod_status (CVE-2020-25073)
- bepasty: New app for file upload and sharing
- matrixsynapse: Allow upgrade to version 1.19
Other Changes
- apps: Remove Coquelicot
- backups: Make app available by default
- debian: Add newline to end of /var/lib/plinth/firstboot-wizard-secret
- debian: Don’t show first wizard secret on command line
- debian: Temporarily revert source package rename
- diagnostics: Prevent showing running status on diagnostics menu item
- doc: Add moinmoin wiki parser
- doc: Fix wiki links in manual
- ejabberd, mumble, wireguard: Update Apple app links
- ejabberd: Use new ruamel.yaml API and allow duplicate keys
- firewall: Show port forwarding info contextually
- firewall: Show port forwarding info in tabular format
- gitweb: Add ability to change default branch
- gitweb: Fix enable auth webserver component on app init
- help, networks: Clarify i18n different contexts for “Manual”
- i18n: Mark strings missed for translation
- ikiwiki: Validate a path when deleting wiki or blog
- js: Don’t show running status on buttons pulled to right
- jsxc, sharing, wireguard: Add ‘Learn more…’ link for help pages
- locale: Update translations for Danish, Dutch, Galician, German, Hungarian, Italian, Spanish, Swedish, Russian, Turkish
- matrixsynapse: Perform a one time conversion to new config format
- matrixsynapse: Rename Riot to Element
- matrixsynapse: Use conf.d snippets
- radicale: Remove code to handle 1.x
- radicale: Stop service during backup and restore
- samba: Hide common system partitions
- snapshots: Clarify description for disabling yearly snapshots
- ssh: Disallow managing keys for the root user
- storage: Fix expanding partitions on GPT partition tables
- upgrades, security: Update the messages describing backports
- upgrades: Add first boot step to configure backports
- upgrades: Change backports activation message wording
- upgrades: Display correct backports info for unstable
- upgrades: security: Don’t use technical term ‘backports’ in UI
- wireguard: Remove hardcoded Windows client version
- Artem
- Burak Yavuz
- Diego Roversi
- Dietmar
- Doma Gergő
- Fioddor Superconcentrado
- ikmaak
- James Valleroy
- Jens Molgaard
- Johannes Keyser
- Joseph Nuthalapati
- Michael Breidenbach
- Nikita Epifanov
- Q.-A. Nick
- Ralf Barkow
- Reg Me
- Sunil Mohan Adapa
- Veiko Aasa
- Xosé M
- Павел Протасов
