I am trying get FreedomBox working on a Armbian system, but it doesn’t work.
I don’t know for sure why, but I think it is because the firewall isn’t being setup properly and it is blocking web access from any device on the local network.
I think that there is slight differences in the way networking functions on Armbian so the Debian install doesn’t work properly after successfully downloading everything.
There is a lot of devices that armbian can be installed on, so it would be nice to figure what needs to be done on an armbian box to get it working properly.
We want to support installation of FreedomBox on Armbian.
FreedomBox uses firewalld as a firewall. This in turn uses nftables. I see no reason why it should not work on Ambian. Please post the output of systemctl status firewalld.service and journalctl -u firewalld.service.
If networking is configured in /etc/network/interfaces (likely on Ambian) then FreedomBox (through NetworkManager) does not interfere with that configuration. So, it should play well with Armbian like it does with Debian.
Please post more debugging information so that we can isolate and fix the issue.
I came across this as I was looking for documentation on how to manually install other apps on Armbian and it is all I needed to do to get Freedombox working on a Armbian device.
Thanks for the detailed steps. Perhaps purging the netplan.io package and rebooting the machine might also work since NetworkManager’s default behavior is to manage all devices that are not part of ifupdown configuration. Or could be missing something.
