Hello All,
After a software update I get the error which I posted below. All so I have posted the out put of the command apt update after the software update. Because of a issue with the file: freedombox-unstable.list
Regards: peter
Before Software Update Fbx version was: 25.9.3 and after the Software Update Fbx version is: 25.16
Debian 13 VPS at Contabo.
Below is the error from the Software Update page:
Error loading page. Details
File "/usr/lib/python3/dist-packages/django/core/handlers/base.py", line 197, in _get_response
File "/usr/lib/python3/dist-packages/django/views/generic/base.py", line 105, in view
File "/usr/lib/python3/dist-packages/plinth/views.py", line 351, in dispatch
File "/usr/lib/python3/dist-packages/django/views/generic/base.py", line 144, in dispatch
File "/usr/lib/python3/dist-packages/django/views/generic/edit.py", line 144, in get
return self.render_to_response(self.get_context_data())
File "/usr/lib/python3/dist-packages/plinth/modules/upgrades/views.py", line 41, in get_context_data
context = super().get_context_data(*args, **kwargs)
File "/usr/lib/python3/dist-packages/plinth/views.py", line 443, in get_context_data
File "/usr/lib/python3/dist-packages/django/views/generic/edit.py", line 74, in get_context_data
kwargs["form"] = self.get_form()
File "/usr/lib/python3/dist-packages/plinth/views.py", line 390, in get_form
File "/usr/lib/python3/dist-packages/django/views/generic/edit.py", line 39, in get_form
return form_class(**self.get_form_kwargs())
File "/usr/lib/python3/dist-packages/django/views/generic/edit.py", line 44, in get_form_kwargs
"initial": self.get_initial(),
File "/usr/lib/python3/dist-packages/plinth/modules/upgrades/views.py", line 35, in get_initial
'auto_upgrades_enabled': privileged.check_auto(),
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 73, in wrapper
module_name = _get_privileged_action_module_name(func)
action_name = func.__name__
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 134, in _run_privileged_method_as_process
File "/usr/lib/python3/dist-packages/plinth/actions.py", line 150, in _wait_for_return
client_socket)
subprocess.CalledProcessError: Command '['sudo', '--non-interactive', '--
After I got the above error from the Software Update.
I had a issue with with apt update on the command line.
It out put is shown below.
To resolve this issue with apt update I edited the file: /etc/apt/sources.list.d/freedombox-unstable.list And removed: tor+
Tor had not been installed.
E: The method driver /usr/lib/apt/methods/tor+http could not be found.
N: Is the package apt-transport-tor installed?
E: Failed to fetch tor+http://deb.debian.org/debian/dists/unstable/InRelease
E: Some index files failed to download. They have been ignored, or old ones used instead.
