Hello All and thank you !
I have just done a Debian testing “bullseye” install. The image that was down loaded was Daily build: 2021-02-22 16:04 361M. The base install worked perfectly.
I did format the hard drive to: Btrfs on the install.
Then I installed the freedombox package:
sudo DEBIAN_FRONTEND=noninteractive apt install freedombox
Then I edited the interfaces file to:
auto lo
iface lo inet loopback
Then a reboot and the boot stops with the message:
[FAILED] Failed to mount /. snapshots
[DEPEND] Dependency failed for local file System.
You are in emergency mode.
It will not move post the message. I have done two installs and same problem !
Regards: peter
Hardware:
Laptop: LENOVO 0769ECG
Same again to day with:
2021-02-23
firmware-testing-amd64-netinst.iso
Update:
I log in at the: You are in emergency mode.
And # out the line for:
#UUID=eb9994cd-31cf-4c05-af9d-78554da15ee9 /.snapshots btrfs subvol=.snapshots 0 1
I can now get a full boot and get to freedombox setup page.
