When installing this way LDAP will not work as I disable it so you will get an error message on the Web Interface loading, but everything appears to work. You can probably setup LDAP and get that error message to disappear.
FreedomBox needs docker to ipv6 config setup.
my docker config looks like this:
/etc/docker/daemon.json
“userland-proxy”: false,
“iptables”: true,
“ipv6”: true,
“fixed-cidr-v6”: “2001:db8:1::/64”
Cut and paste the following code into shell script and run as docker user:
#!/bin/bash
docker run -itd --name freedombox --privileged -v /run/systemd/system:/run/systemd/system -v /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket -p 4445:80 -p 4446:443 debian:unstable /bin/bash
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin DEBIAN_FRONTEND=noninteractive apt update"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin DEBIAN_FRONTEND=noninteractive apt install snapd freedombox systemd syslog-ng mariadb-server -y"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin DEBIAN_FRONTEND=noninteractive apt purge resolvconf -y"
docker commit freedombox freedombox
docker stop freedombox
docker rm freedombox
docker run -itd --name freedombox --privileged -v /run/systemd/system:/run/systemd/system -v /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket -p 4445:80 -p 4446:443 --entrypoint /sbin/init freedombox
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl enable snapd"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl start snapd"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin snap install core"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl restart snapd"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl enable apache2"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl enable uwsgi"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl start apache2"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl start uwsgi"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl enable syslog-ng"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl start syslog-ng"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl disable slapd"
docker exec -it freedombox sh -c "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin systemctl stop slapd"
1> root@944457c6fee1:/# vi /usr/lib/python3/dist-packages/plinth/modules/storage/__init__.py
look for this code and change def get_filesystem_type(mount_point=’/’):
“”“Returns the type of the filesystem mounted at mountpoint.”“”
for partition in psutil.disk_partitions():
if partition.mountpoint == mount_point:
return partition.fstype
and make it this:
“”“Returns the type of the filesystem mounted at mountpoint.”""
for partition in psutil.disk_partitions(all=True):
2> root@944457c6fee1:# systemctl start plinth
3> root@944457c6fee1:# systemctl start firewalld
(woops we need this , importnant component for auto-configs…possibly)
4> browse to your port things should be and running see screen shots attached:
Grab the password
When you log in you’ll see this enter and start setting things up:
Enter the secret generated during FreedomBox installation. This secret can also be obtained by running the command “sudo cat /var/lib/plinth/firstboot-wizard-secret” on your FreedomBox
After the install I used the FreedomBox to install those applications without modification
All Applications that were installed pretty quickly after changes mentioned.
When installing RoundCube you need to start the apache server back up there is a small bug that it kills the server and doesnt restart:
docker exec -it freedombox /bin/bash
If you want I2P working there is a small bug you need to fix:
edit the following file:
change both files here
vi /usr/share/plinth/actions/i2p
vi /usr/lib/python3/dist-packages/plinth/modules/i2p/helpers.py
Look in the files (first 4 lines in mine, and replace )
I2P_CONF_DIR =‘/var/lib/i2p/i2p-config/’
change to
I2P_CONF_DIR = ‘/usr/share/i2p’
And it should install ok.
