Hi,
First time posting here, so I just wanted to say this project is amazing and all of the good people who help maintain this are doing some great work! Thank You So Very Much! I plan on actively promoting this project once I can get my own instance sorted out.
Now to the problem I am experiencing: I cannot access the Cockpit from the Admin Page. I am met with:
Connection failed
There was an unexpected error while connecting to the machine.
Messages related to the failure might be found in the journal:
journalctl -u cockpit
Been reading through the guide ( FreedomBox/Manual/Cockpit - Debian Wiki ), so hopefully it is up to date/complete.
The biggest clue I have found so far is that I cannot seem to access the FreedomBox portal or Cockpit from the domain I registered with the system during the initial setup. *I installed FB on a fresh install of Debian 11 on my own PC if that matters at all.
I can only seem to access the FB portal from the local IP of my server, but I realize that is not going to work with Cockpit as the documentation states. Everything in the FB portal seems to work fine, but Cockpit refuses to open. Did I do something wrong during the initial freedombox install, or perhaps something went wrong?
Here is the contents of my cockpit.conf:
*NOTE: I tried adding the local ip of my server to the cockpit.conf file (such as: https://192.168.x.x) for troubleshooting purposes, rebooted the server, but itās the same issue. I realize that probably wonāt work any, but I donāt know what else to look for. Iām not an expert with Linux, but Iām not totally helpless either and willing to read/learn!
Here are the contents of the journal. Unfortunately, it doesnāt say much.
Blockquote
ā Journal begins at Tue 2022-07-19 12:32:04 MST, ends at Wed 2022-07-20 09:33:26 MST. ā
Jul 19 19:35:05 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 19 19:35:06 debian systemd[1]: Started Cockpit Web Service.
Jul 19 19:39:15 debian systemd[1]: cockpit.service: Succeeded.
ā Boot bf8f20c4621741b88db3e101ad2e0bd6 ā
Jul 20 06:34:53 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 06:34:53 debian systemd[1]: Started Cockpit Web Service.
Jul 20 06:36:47 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:11:40 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:11:40 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:13:22 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:13:27 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:13:27 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:18:23 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:18:54 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:18:54 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:20:55 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:28:12 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:28:12 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:30:59 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:35:33 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:35:33 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:39:20 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 07:58:29 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 07:58:29 debian systemd[1]: Started Cockpit Web Service.
Jul 20 07:59:59 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 08:03:32 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 08:03:32 debian systemd[1]: Started Cockpit Web Service.
Jul 20 08:05:34 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 08:11:10 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 08:11:10 debian systemd[1]: Started Cockpit Web Service.
Jul 20 08:13:52 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 08:22:52 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 08:22:52 debian systemd[1]: Started Cockpit Web Service.
Jul 20 08:24:57 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 08:37:36 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 08:37:36 debian systemd[1]: Started Cockpit Web Service.
Jul 20 08:39:40 debian systemd[1]: cockpit.service: Succeeded.
ā Boot 613ab3180c53435eb6c9d4b4b4b50917 ā
Jul 20 09:25:53 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 09:25:53 debian systemd[1]: Started Cockpit Web Service.
Jul 20 09:27:23 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 09:28:07 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 09:28:07 debian systemd[1]: Started Cockpit Web Service.
Jul 20 09:29:37 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 09:30:14 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 09:30:14 debian systemd[1]: Started Cockpit Web Service.
Jul 20 09:32:18 debian systemd[1]: cockpit.service: Succeeded.
Jul 20 09:32:49 debian systemd[1]: Starting Cockpit Web Serviceā¦
Jul 20 09:32:49 debian systemd[1]: Started Cockpit Web Service.
Blockquote
*Please let me know if any other info. is needed of if I forgot some critical details. Thank You!
