I have a Pioneer that have been working fine for months with radicale, ejabberd, coturn, quassel, post/fixdovecot and synthing. I use the version with SSD and everything moved to the SSD except /boot. Except for the moving of the filesystem, everything is as installed by the official image and plinth, no tweaking of anything.
The recent modifications are the addition of matrix (no public registration) added last week, not much used (only 2 active users to send a few messages between each other, trying it due to a situation where I can’t make Monal on iOS and Gajim on a new machine successfully decode each other with OMEMO).
Yesterday, I installed roundcube and, a few hours later, Mediawiki.
Within a few minutes (2-3 at most) of installing Mediawiki, the web interface became unavaible while I could still ssh to my Pioneer. Apparently, postfix/dovecot, radicale, ejabberd and quassel were still working fine (I did not test further things).
I asked to reboot, the web interface came back, but it very quickly died again. Finally, I rebooted and connected with ssh early on and displayed the journal. Apparently, apache is crashing. I thought that I could try restarting some service with systemctl restart, so I tried restarting plinth, that does not bring the web interface back. I tried restarting apache2, then the web interface is back, but it is gone again after a few minutes. I restarted apache2 and hurried to deactivate Mediawiki, then no more problem, web interface stays up.
I include extracts of journalctl that might show useful things to see what was happening:
avril 22 21:45:49 fbox /usr/bin/plinth[520]: AXES: Using django-axes version 5.4.3
avril 22 21:45:49 fbox /usr/bin/plinth[520]: AXES: blocking by IP only.
avril 22 21:45:50 fbox syncthing[1106]: [UJECI] INFO: Listen (BEP/relay): Get "https://relays.syncthing.net/endpoint": net/http: TLS handshake timeout
avril 22 21:45:50 fbox syncthing[1106]: [UJECI] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
avril 22 21:45:51 fbox syncthing[1106]: [UJECI] INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.765268 failures of 2.000000), restarting: true, error: %!s(<nil>)
avril 22 21:45:51 fbox syncthing[1106]: [UJECI] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
avril 22 21:45:51 fbox sudo[1369]: pam_unix(sudo:auth): authentication failure; logname=fbox_admin uid=10000 euid=0 tty=/dev/pts/0 ruser=fbox_admin rhost= user=fbox_admin
avril 22 21:45:51 fbox slapd[979]: slap_global_control: unrecognized control: 1.3.6.1.4.1.42.2.27.8.5.1
avril 22 21:45:51 fbox sudo[1369]: fbox_admin : TTY=pts/0 ; PWD=/home/fbox_admin ; USER=root ; COMMAND=/usr/bin/journalctl -f
avril 22 21:45:51 fbox sudo[1369]: pam_unix(sudo:session): session opened for user root(uid=0) by fbox_admin(uid=10000)
avril 22 21:45:54 fbox audit[1519]: AVC apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/sys/fs/cgroup/cgroup.controllers" pid=1519 comm="beam.smp" requested_mask="r" denied_mask="r" fsuid=118 ouid=0
avril 22 21:45:54 fbox kernel: audit: type=1400 audit(1682192754.262:26): apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/sys/fs/cgroup/cgroup.controllers" pid=1519 comm="beam.smp" requested_mask="r" denied_mask="r" fsuid=118 ouid=0
avril 22 21:45:54 fbox kernel: audit: type=1400 audit(1682192754.266:27): apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/sys/fs/cgroup/cgroup.controllers" pid=1519 comm="beam.smp" requested_mask="r" denied_mask="r" fsuid=118 ouid=0
avril 22 21:45:54 fbox audit[1532]: AVC apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/proc/1532/fd/" pid=1532 comm="erl_child_setup" requested_mask="r" denied_mask="r" fsuid=118 ouid=118
avril 22 21:45:54 fbox kernel: audit: type=1400 audit(1682192754.510:28): apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/proc/1532/fd/" pid=1532 comm="erl_child_setup" requested_mask="r" denied_mask="r" fsuid=118 ouid=118
avril 22 21:45:55 fbox /usr/bin/plinth[520]: FreedomBox Service (Plinth) version - 23.6
avril 22 21:45:55 fbox /usr/bin/plinth[520]: Script prefix - /plinth
avril 22 21:45:56 fbox systemd[1]: matrix-synapse.service: start-pre operation timed out. Terminating.
avril 22 21:45:57 fbox systemd[1]: matrix-synapse.service: Control process exited, code=killed, status=15/TERM
avril 22 21:45:57 fbox systemd[1]: matrix-synapse.service: Failed with result 'timeout'.
avril 22 21:45:57 fbox systemd[1]: Failed to start Synapse Matrix homeserver.
avril 22 21:45:57 fbox systemd[1]: matrix-synapse.service: Consumed 20.581s CPU time.
avril 22 21:45:57 fbox audit[547]: AVC apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/etc/ssl/openssl.cnf" pid=547 comm="1_scheduler" requested_mask="r" denied_mask="r" fsuid=118 ouid=0
avril 22 21:45:57 fbox kernel: audit: type=1400 audit(1682192757.946:29): apparmor="ALLOWED" operation="open" profile="/usr/sbin/ejabberdctl" name="/etc/ssl/openssl.cnf" pid=547 comm="1_scheduler" requested_mask="r" denied_mask="r" fsuid=118 ouid=0
avril 22 21:45:59 fbox apache-error[1207]: [proxy:error] [pid 1227:tid 1227] (111)Connection refused: AH00957: http: attempt to connect to 127.0.0.1:8000 (127.0.0.1:8000) failed
avril 22 21:45:59 fbox apache-error[1207]: [proxy_http:error] [pid 1227:tid 1227] [client 192.168.10.51:37280] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
avril 22 21:45:59 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:45:59 +0200] "GET /plinth HTTP/1.1" 503 910 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:46:00 fbox systemd[1]: matrix-synapse.service: Scheduled restart job, restart counter is at 1.
avril 22 21:46:00 fbox systemd[1]: Stopped Synapse Matrix homeserver.
avril 22 21:46:00 fbox systemd[1]: matrix-synapse.service: Consumed 20.581s CPU time.
avril 22 21:46:00 fbox systemd[1]: Starting Synapse Matrix homeserver...
avril 22 21:46:02 fbox syncthing[1106]: [UJECI] INFO: Listen (BEP/relay): Get "https://relays.syncthing.net/endpoint": net/http: TLS handshake timeout
avril 22 21:46:02 fbox syncthing[1106]: [UJECI] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
avril 22 21:46:03 fbox syncthing[1106]: [UJECI] INFO: c.S.listenerSupervisor: Entering the backoff state.
avril 22 21:46:04 fbox syncthing[1106]: [UJECI] INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (2.321553 failures of 2.000000), restarting: false, error: %!s(<nil>)
avril 22 21:46:08 fbox systemd[1]: Started robust, scalable and extensible realtime platform (XMPP server + MQTT broker + SIP service).
avril 22 21:46:09 fbox /usr/bin/plinth[520]: Initialized apps - apache, api, names, avahi, storage, backups, cockpit, firewall, config, datetime, diagnostics, dynamicdns, first_boot, help, letsencrypt, networks, power, security, snapshot, ssh, sso, upgrades, users, privacy, bepasty, bind, calibre, coturn, deluge, ejabberd, gitweb, i2p, ikiwiki, infinoted, jsxc, matrixsynapse, mediawiki, minetest, minidlna, mumble, openvpn, pagekite, performance, privoxy, quassel, radicale, roundcube, samba, searx, shaarli, shadowsocks, sharing, syncthing, tor, transmission, ttrss, wireguard, wordpress, zoph, email, janus, rssbridge
avril 22 21:46:10 fbox /usr/bin/plinth[520]: Added domain fbox.local of type domain-type-local with services __all__
avril 22 21:46:13 fbox /usr/bin/plinth[520]: Added domain metani.eu of type domain-type-static with services __all__
avril 22 21:46:15 fbox apache-error[1207]: [proxy:error] [pid 1229:tid 1229] (111)Connection refused: AH00957: http: attempt to connect to 127.0.0.1:8000 (127.0.0.1:8000) failed
avril 22 21:46:15 fbox apache-error[1207]: [proxy_http:error] [pid 1229:tid 1229] [client 192.168.10.51:42104] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
avril 22 21:46:15 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:46:15 +0200] "GET /plinth HTTP/1.1" 503 910 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:46:17 fbox /usr/bin/plinth[520]: # ikiwiki..get_sites(…)
avril 22 21:46:17 fbox sudo[1724]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions ikiwiki get_sites --write-fd 7
avril 22 21:46:17 fbox sudo[1724]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=115)
avril 22 21:46:18 fbox rspamd[1354]: <imhkkk>; monitored; rspamd_monitored_dns_cb: DNS query blocked on multi.uribl.com (127.0.0.1 returned), possibly due to high volume
avril 22 21:46:19 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - david [22/Apr/2023:21:45:44 +0200] "REPORT /radicale/david/bd53139b-af62-c027-5170-b627bf3f0f17/ HTTP/1.1" 207 6899 "-" "Evolution/3.44.4"
avril 22 21:46:26 fbox postfix/postfix-script[1779]: warning: not owned by postfix: /var/lib/postfix/./freedombox-aliases
avril 22 21:46:27 fbox postfix/postfix-script[1780]: warning: not owned by postfix: /var/lib/postfix/./freedombox-aliases/aliases.sqlite3
avril 22 21:46:29 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - david [22/Apr/2023:21:46:19 +0200] "REPORT /radicale/david/bd53139b-af62-c027-5170-b627bf3f0f17/ HTTP/1.1" 207 37343 "-" "Evolution/3.44.4"
avril 22 21:46:31 fbox apache-error[1207]: [proxy:error] [pid 1220:tid 1220] (111)Connection refused: AH00957: http: attempt to connect to 127.0.0.1:8000 (127.0.0.1:8000) failed
avril 22 21:46:31 fbox apache-error[1207]: [proxy_http:error] [pid 1220:tid 1220] [client 192.168.10.51:56746] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
avril 22 21:46:31 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:46:31 +0200] "GET /plinth HTTP/1.1" 503 910 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:46:31 fbox postfix/postfix-script[1953]: starting the Postfix mail system
avril 22 21:46:32 fbox postfix/master[1955]: daemon started -- version 3.5.17, configuration /etc/postfix
avril 22 21:46:32 fbox systemd[1]: Started Postfix Mail Transport Agent (instance -).
avril 22 21:46:32 fbox systemd[1]: Starting Postfix Mail Transport Agent...
avril 22 21:46:32 fbox systemd[1]: Finished Postfix Mail Transport Agent.
avril 22 21:46:38 fbox sudo[1724]: pam_unix(sudo:session): session closed for user root
avril 22 21:46:41 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - david [22/Apr/2023:21:45:45 +0200] "PROPFIND /radicale/david/26ec9dde-14e8-4bc1-34ff-3081e48a3f53/ HTTP/1.1" 207 48312 "-" "Evolution/3.44.4"
avril 22 21:46:42 fbox rspamd[1354]: <imhkkk>; monitored; rspamd_monitored_dns_cb: DNS query blocked on multi.uribl.com (127.0.0.1 returned), possibly due to high volume
avril 22 21:46:43 fbox syncthing[1106]: [UJECI] INFO: Listen (BEP/tcp): TLS handshake: write tcp 192.168.10.66:22000->192.168.10.51:22000: i/o timeout
avril 22 21:46:45 fbox /usr/bin/plinth[520]: Checking if any Let's Encrypt certificates got renewed.
avril 22 21:46:45 fbox /usr/bin/plinth[520]: # letsencrypt..get_status(…)
avril 22 21:46:45 fbox sudo[2018]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions letsencrypt get_status --write-fd 7
avril 22 21:46:45 fbox sudo[2018]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=115)
avril 22 21:46:47 fbox apache-error[1207]: [proxy:error] [pid 1467:tid 1467] (111)Connection refused: AH00957: http: attempt to connect to 127.0.0.1:8000 (127.0.0.1:8000) failed
avril 22 21:46:47 fbox apache-error[1207]: [proxy_http:error] [pid 1467:tid 1467] [client 192.168.10.51:50284] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
avril 22 21:46:47 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:46:47 +0200] "GET /plinth HTTP/1.1" 503 910 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:46:54 fbox rspamd[1354]: <imhkkk>; monitored; rspamd_monitored_dns_cb: DNS query blocked on multi.uribl.com (127.0.0.1 returned), possibly due to high volume
avril 22 21:46:54 fbox rspamd[1354]: <imhkkk>; monitored; rspamd_monitored_propagate_error: invalid return on resolving multi.uribl.com, disable object
avril 22 21:46:54 fbox rspamd[1354]: <kecb3d>; cfg; rspamd_worker_monitored_on_change: broadcast monitored update for imhkkkzu76dtxr3ajyrpn947zwx9kfa: dead
avril 22 21:46:54 fbox rspamd[1356]: <kecb3d>; cfg; rspamd_worker_monitored_handler: updated monitored status for imhkkkzu76dtxr3ajyrpn947zwx9kfa: dead
avril 22 21:47:01 fbox sudo[2018]: pam_unix(sudo:session): session closed for user root
avril 22 21:47:01 fbox /usr/bin/plinth[520]: Certificate for metani.eu is already the latest known.
avril 22 21:47:02 fbox /usr/bin/plinth[520]: Running regular setup.
avril 22 21:47:02 fbox /usr/bin/plinth[520]: Started new thread for glib main loop.
avril 22 21:47:02 fbox /usr/bin/plinth[520]: Setting up CherryPy server
avril 22 21:47:02 fbox /usr/bin/plinth[520]: Creating network manager client
avril 22 21:47:02 fbox /usr/bin/plinth[520]: D-Bus connection acquired: org.freedombox.Service
avril 22 21:47:02 fbox /usr/bin/plinth[520]: D-Bus name acquired: org.freedombox.Service
avril 22 21:47:02 fbox apache-error[1207]: [proxy:error] [pid 1227:tid 1227] (111)Connection refused: AH00957: http: attempt to connect to 127.0.0.1:8000 (127.0.0.1:8000) failed
avril 22 21:47:02 fbox apache-error[1207]: [proxy_http:error] [pid 1227:tid 1227] [client 192.168.10.51:56516] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
avril 22 21:47:02 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:02 +0200] "GET /plinth HTTP/1.1" 503 910 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:02 fbox /usr/bin/plinth[520]: Created Network manager client
avril 22 21:47:03 fbox /usr/bin/plinth[520]: Drive SPCC-Solid-State-Disk-30076351369 appears healthy
avril 22 21:47:04 fbox /usr/bin/plinth[520]: Running setup for apps, essential - True, selected apps - None
avril 22 21:47:04 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:04] ENGINE Listening for SIGTERM.
avril 22 21:47:04 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:04] ENGINE Listening for SIGHUP.
avril 22 21:47:04 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:04] ENGINE Listening for SIGUSR1.
avril 22 21:47:04 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:04] ENGINE Bus STARTING
avril 22 21:47:04 fbox /usr/bin/plinth[520]: Setup thread finished.
avril 22 21:47:04 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:04] ENGINE Started monitor thread '_TimeoutMonitor'.
avril 22 21:47:05 fbox /usr/bin/plinth[520]: New filesystem found: by-uuid-57198cbe-845c-48a8-9e26-c61f93bd6abd /dev/mmcblk0p1
avril 22 21:47:05 fbox /usr/bin/plinth[520]: Ignoring auto-mount on already mounted device: by-uuid-57198cbe-845c-48a8-9e26-c61f93bd6abd /dev/mmcblk0p1
avril 22 21:47:05 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:05] ENGINE Serving on http://127.0.0.1:8000
avril 22 21:47:05 fbox /usr/bin/plinth[520]: [22/Apr/2023:21:47:05] ENGINE Bus STARTED
avril 22 21:47:05 fbox /usr/bin/plinth[520]: New filesystem found: by-id-ata-SPCC_Solid_State_Disk_30076351369 /dev/sda
avril 22 21:47:05 fbox /usr/bin/plinth[520]: Ignoring auto-mount on already mounted device: by-id-ata-SPCC_Solid_State_Disk_30076351369 /dev/sda
avril 22 21:47:08 fbox syncthing[1106]: [UJECI] INFO: Listen (BEP/tcp): TLS handshake: write tcp 192.168.10.66:22000->192.168.10.51:22000: i/o timeout
avril 22 21:47:13 fbox /usr/bin/plinth[520]: # users..get_user_groups(…)
avril 22 21:47:13 fbox sudo[2052]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions users get_user_groups --write-fd 17
avril 22 21:47:13 fbox sudo[2052]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=115)
avril 22 21:47:18 fbox ldapsearch[2093]: DIGEST-MD5 common mech free
avril 22 21:47:18 fbox ldapsearch[2100]: DIGEST-MD5 common mech free
avril 22 21:47:18 fbox ldapsearch[2110]: DIGEST-MD5 common mech free
avril 22 21:47:18 fbox ldapsearch[2120]: DIGEST-MD5 common mech free
avril 22 21:47:18 fbox ldapsearch[2136]: DIGEST-MD5 common mech free
avril 22 21:47:19 fbox sudo[2052]: pam_unix(sudo:session): session closed for user root
avril 22 21:47:20 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:13 +0200] "GET /plinth HTTP/1.1" 200 4937 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:23 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:23 +0200] "GET /mediawiki HTTP/1.1" 301 598 "https://metani.eu/plinth" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:29 fbox python3[2029]: WARNING: The 'room_invite_state_types' configuration setting is now deprecated,
avril 22 21:47:29 fbox python3[2029]: and replaced with 'room_prejoin_state'. New features may not work correctly
avril 22 21:47:29 fbox python3[2029]: unless 'room_invite_state_types' is removed. See the config documentation at
avril 22 21:47:29 fbox python3[2029]: https://matrix-org.github.io/synapse/latest/usage/configuration/config_documentation.html#room_prejoin_state
avril 22 21:47:29 fbox python3[2029]: for details of 'room_prejoin_state'.
avril 22 21:47:29 fbox python3[2029]: --------------------------------------------------------------------------------
avril 22 21:47:29 fbox python3[2029]: This server is configured to use 'matrix.org' as its trusted key server via the
avril 22 21:47:29 fbox python3[2029]: 'trusted_key_servers' config option. 'matrix.org' is a good choice for a key
avril 22 21:47:29 fbox python3[2029]: server since it is long-lived, stable and trusted. However, some admins may
avril 22 21:47:29 fbox python3[2029]: wish to use another server for this purpose.
avril 22 21:47:29 fbox python3[2029]: To suppress this warning and continue using 'matrix.org', admins should set
avril 22 21:47:29 fbox python3[2029]: 'suppress_key_server_warning' to 'true' in homeserver.yaml.
avril 22 21:47:29 fbox python3[2029]: Config is missing macaroon_secret_key
avril 22 21:47:30 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:24 +0200] "GET /mediawiki/ HTTP/1.1" 200 3951 "https://metani.eu/plinth" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:30 fbox synapse[2029]: root: [main] ***** STARTING SERVER *****
avril 22 21:47:30 fbox synapse[2029]: root: [main] Server /usr/lib/python3/dist-packages/synapse/app/homeserver.py version 1.78.0
avril 22 21:47:31 fbox syncthing[1106]: [UJECI] INFO: Established secure connection to BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ at 192.168.10.66:41876-193.219.28.151:443/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
avril 22 21:47:31 fbox syncthing[1106]: [UJECI] INFO: Device BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ client is "syncthing v1.18.0-ds1" named "albert trisquel 11" at 192.168.10.66:41876-193.219.28.151:443/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
avril 22 21:47:31 fbox syncthing[1106]: [UJECI] INFO: Unexpected folder "Seafile profil" (fjmhi-zfx9g) sent from device "BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ"; ensure that the folder exists and that this device is selected under "Share With" in the folder configuration.
avril 22 21:47:32 fbox synapse[2029]: synapse.app: [sentinel] Failed to listen on 0.0.0.0, continuing because listening on [::]
avril 22 21:47:32 fbox systemd[1]: Started Synapse Matrix homeserver.
avril 22 21:47:32 fbox systemd[1]: Reached target Multi-User System.
avril 22 21:47:32 fbox systemd[1]: Reached target Graphical Interface.
avril 22 21:47:32 fbox systemd[1]: Starting Update UTMP about System Runlevel Changes...
avril 22 21:47:32 fbox systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
avril 22 21:47:32 fbox systemd[1]: Finished Update UTMP about System Runlevel Changes.
avril 22 21:47:32 fbox systemd[1]: Startup finished in 11.503s (kernel) + 3min 16.288s (userspace) = 3min 27.792s.
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:30 +0200] "GET /mediawiki/load.php?lang=en&modules=startup&only=scripts&raw=1&skin=timeless HTTP/1.1" 200 13174 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:30 +0200] "GET /mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless HTTP/1.1" 200 10967 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/skins/Timeless/resources/images/user-grey.svg?49b1e HTTP/1.1" 200 701 "https://metani.eu/mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/resources/assets/mediawiki.png?2923d HTTP/1.1" 200 13937 "https://metani.eu/mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/skins/Timeless/resources/images/arrow-down-grey.svg?ce6b9 HTTP/1.1" 200 899 "https://metani.eu/mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/skins/Timeless/resources/images/search-ltr.svg?26600 HTTP/1.1" 200 673 "https://metani.eu/mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/skins/Timeless/resources/images/cat.svg?16717 HTTP/1.1" 200 10884 "https://metani.eu/mediawiki/load.php?lang=en&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cmediawiki.skinning.content.externallinks%7Cskins.timeless&only=styles&skin=timeless" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/resources/assets/poweredby_mediawiki_88x31.png HTTP/1.1" 200 4210 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/resources/assets/debian/poweredby_debian_1x.png HTTP/1.1" 200 3919 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:39 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/resources/assets/freedombox/poweredby_freedombox.svg HTTP/1.1" 200 7334 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:40 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/load.php?lang=en&modules=ext.visualEditor.core.utils.parsing%7Cext.visualEditor.desktopArticleTarget.init%7Cext.visualEditor.progressBarWidget%2CsupportCheck%2CtargetLoader%2CtempWikitextEditorWidget%2Ctrack%2Cve&skin=timeless&version=3gs2u HTTP/1.1" 200 15966 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:41 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:39 +0200] "GET /mediawiki/load.php?lang=en&modules=jquery%2Csite%7Cjquery.client%2Ccookie%2CtextSelection%7Cmediawiki.String%2CTitle%2CUri%2Capi%2Cbase%2Ccldr%2Ccookie%2CjqueryMsg%2Clanguage%2Cstorage%2Cuser%2Cutil%7Cmediawiki.editfont.styles%7Cmediawiki.libs.pluralruleparser%7Cmediawiki.page.ready%2Cstartup%7Cskins.timeless.js%2Cmobile%7Cuser.defaults&skin=timeless&version=1qdok HTTP/1.1" 200 86602 "https://metani.eu/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:47 fbox syncthing[1106]: [UJECI] INFO: Established secure connection to BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ at 192.168.10.66:22000-192.168.10.51:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
avril 22 21:47:47 fbox syncthing[1106]: [UJECI] INFO: Replacing old connection 192.168.10.66:41876-193.219.28.151:443/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 with 192.168.10.66:22000-192.168.10.51:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 for BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ
avril 22 21:47:47 fbox syncthing[1106]: [UJECI] INFO: Connection to BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ at 192.168.10.66:41876-193.219.28.151:443/relay-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 closed: replacing connection
avril 22 21:47:47 fbox syncthing[1106]: [UJECI] INFO: Device BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ client is "syncthing v1.18.0-ds1" named "albert trisquel 11" at 192.168.10.66:22000-192.168.10.51:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
avril 22 21:47:47 fbox syncthing[1106]: [UJECI] INFO: Unexpected folder "Seafile profil" (fjmhi-zfx9g) sent from device "BBTREGI-VVYENQQ-WHKRCF6-C2MCLOJ-FNDECXH-5AQ5YY4-3IJWLEQ-O3YDMAZ"; ensure that the folder exists and that this device is selected under "Share With" in the folder configuration.
avril 22 21:47:54 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:53 +0200] "GET /plinth/apps/ HTTP/1.1" 200 5219 "https://metani.eu/plinth" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:54 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:54 +0200] "GET /plinth/static/theme/icons/coturn.svg HTTP/1.1" 200 855 "https://metani.eu/plinth/apps/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:47:58 fbox /usr/bin/plinth[520]: # mediawiki..public_registrations(…)
avril 22 21:47:58 fbox sudo[2167]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions mediawiki public_registrations --write-fd 18
avril 22 21:47:58 fbox sudo[2167]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=115)
avril 22 21:48:04 fbox sudo[2167]: pam_unix(sudo:session): session closed for user root
avril 22 21:48:04 fbox /usr/bin/plinth[520]: # mediawiki..private_mode(…)
avril 22 21:48:04 fbox sudo[2171]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/actions mediawiki private_mode --write-fd 18
avril 22 21:48:04 fbox sudo[2171]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=115)
avril 22 21:48:09 fbox sudo[2171]: pam_unix(sudo:session): session closed for user root
avril 22 21:48:11 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:47:57 +0200] "GET /plinth/apps/mediawiki/ HTTP/1.1" 200 11315 "https://metani.eu/plinth/apps/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:48:24 fbox rspamd[1354]: <imhkkk>; monitored; rspamd_monitored_dns_cb: DNS query blocked on multi.uribl.com (127.0.0.1 returned), possibly due to high volume
avril 22 21:48:28 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:48:27 +0200] "GET /plinth/sys/ HTTP/1.1" 200 4627 "https://metani.eu/plinth/apps/mediawiki/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:48:30 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:48:30 +0200] "GET /plinth/sys/diagnostics/ HTTP/1.1" 200 4290 "https://metani.eu/plinth/sys/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:48:34 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:48:34 +0200] "POST /plinth/sys/diagnostics/ HTTP/1.1" 302 1014 "https://metani.eu/plinth/sys/diagnostics/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:48:51 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:48:34 +0200] "GET /plinth/sys/diagnostics/ HTTP/1.1" 200 4473 "https://metani.eu/plinth/sys/diagnostics/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:49:04 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:48:54 +0200] "GET /plinth/sys/diagnostics/ HTTP/1.1" 200 4473 "https://metani.eu/plinth/sys/diagnostics/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:49:15 fbox apache-access[1209]: metani.eu:443 192.168.10.51 - - [22/Apr/2023:21:49:07 +0200] "GET /plinth/sys/diagnostics/ HTTP/1.1" 200 4827 "https://metani.eu/plinth/sys/diagnostics/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/112.0"
avril 22 21:49:26 fbox systemd[1]: mediawiki-jobrunner.service: Service reached runtime time limit. Stopping.
avril 22 21:49:26 fbox systemd[1]: mediawiki-jobrunner.service: Failed with result 'timeout'.
avril 22 21:49:26 fbox systemd[1]: mediawiki-jobrunner.service: Consumed 3.623s CPU time.
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1220:tid 1220] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1225:tid 1225] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1337:tid 1337] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1229:tid 1229] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1227:tid 1227] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1222:tid 1222] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 2150:tid 2150] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:26 fbox apache-error[1207]: [mpm_prefork:emerg] [pid 1467:tid 1467] (43)Identifier removed: AH00144: couldn't grab the accept mutex
avril 22 21:49:27 fbox apache-error[1207]: [core:alert] [pid 1206:tid 1206] AH00050: Child 1220 returned a Fatal error... Apache is exiting!
