I don’t want to pollute an existing feed so if you think this deserves to be placed in a separate topic please let me know where to move it. However I think there is some connection with the general feedback and the fact that Olimex is providing support here.
My question is, can I upgrade my Freedombox Pioneer with a wiFi shield for the Lime2 ?
@MikaelB Thanks. I have been starting to play around with the hardware bits (not directly on the Pioneer) but I am wondering if there is a board like shield to upgrade the Lime 2.
Though a shield would mean that the case for the Pioneer wouldn’t fit anymore I was just curious as to what are the requirements for compatibility.
Practically speaking your solution would work for me thank you !
