Hi all,
my Freedombox (Stable-Release) is installed on a RasPi2 and has been running for over two years now.
Today something went wrong: I can no longer access the web frontend (ssh is working fine).
journalctl says:
> Jul 08 18:33:18 freedombox systemd[1]: plinth.service: Main process exited, code=exited, status=1/FAILURE
> Jul 08 18:33:18 freedombox systemd[1]: plinth.service: Failed with result 'exit-code'.
/usr/bin/python3 /usr/bin/plinth leads to:
File "/usr/lib/python3/dist-packages/django/apps/config.py", line 122, in create
cls = getattr(mod, cls_name)
AttributeError: module 'plinth.modules' has no attribute 'apps'
During handling of the above exception, another exception occurred:
File "/usr/bin/plinth", line 21, in <module>
plinth.__main__.main()
File "/usr/lib/python3/dist-packages/plinth/__main__.py", line 146, in main
web_framework.init()
File "/usr/lib/python3/dist-packages/plinth/web_framework.py", line 164, in init
django.setup(set_prefix=True)
File "/usr/lib/python3/dist-packages/django/__init__.py", line 27, in setup
apps.populate(settings.INSTALLED_APPS)
File "/usr/lib/python3/dist-packages/django/apps/registry.py", line 85, in populate
app_config = AppConfig.create(entry)
File "/usr/lib/python3/dist-packages/django/apps/config.py", line 127, in create
import_module(entry)
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 965, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'plinth.modules.apps'
I already tried to update the system (sudo apt-get update, sudo apt-get dist-upgrade). No success so far.
Thank you for your suggestions.
