[SOLVED] Getting Home Assistant to work
I installed Home Assistant on my Freedombox server (debian Firebat mini pc) and it generates errors and crashes
  1. Installed Home Assistant from Plinth apps menu after having created a subdirectory
  2. I run the client to configure the app
  3. I give HA the reference of the subdirectory, disable HA and reenable HA
  4. I go the the subdomain by clicking of the HA icon in the installed apps list
  5. browser sends back “400: Bad Request”
I expected to get the HA web install page as documented in FB docs
The logs:
Oct 16 19:45:50 systemd[1]: Started home-assistant-freedombox.service.
Oct 16 19:45:50 home-assistant-freedombox[9741]: a5ccdc1e5fddc9050a4f750125b5f849495867c56dea68da65a4e39c94b09763
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service s6rc-oneshot-runner: starting
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service s6rc-oneshot-runner successfully started
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service fix-attrs: starting
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service fix-attrs successfully started
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service legacy-cont-init: starting
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service legacy-cont-init successfully started
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service legacy-services: starting
Oct 16 19:45:50 home-assistant-freedombox[9820]: services-up: info: copying legacy longrun home-assistant (no readiness notification)
Oct 16 19:45:50 home-assistant-freedombox[9820]: s6-rc: info: service legacy-services successfully started
Oct 16 19:45:55 home-assistant-freedombox[9820]: 2026-10-16 17:45:55.141 ERROR (MainThread) [habluetooth.manager] Missing required permissions for Bluetooth management. Automatic adapter recovery is unavailable. Add NET_ADMIN and NET_RAW capabilities to the container to enable it
Oct 16 19:45:55 home-assistant-freedombox[9820]: Traceback (most recent call last):
Oct 16 19:45:55 home-assistant-freedombox[9820]: File “src/habluetooth/manager.py”, line 460, in habluetooth.manager.BluetoothManager.async_setup
Oct 16 19:45:55 home-assistant-freedombox[9820]: File “src/habluetooth/channels/bluez.py”, line 750, in setup
Oct 16 19:45:55 home-assistant-freedombox[9820]: PermissionError: Missing NET_ADMIN/NET_RAW capabilities for Bluetooth management
Oct 16 19:45:55 home-assistant-freedombox[9820]: 2026-10-16 17:45:55.599 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.14/site-packages/rich/segment.py:547: SyntaxWarning: ‘return’ in a ‘finally’ block
Oct 16 19:45:55 home-assistant-freedombox[9820]: return
Oct 16 19:45:56 home-assistant-freedombox[9820]: 2026-10-16 17:45:56.323 ERROR (SyncWorker_2) [aiodhcpwatcher] Cannot watch for dhcp packets: [Errno 1] Operation not permitted
Oct 16 19:47:16 home-assistant-freedombox[9820]: 2026-10-16 17:47:16.328 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 127.0.0.1, but your HTTP integration is not set-up for reverse proxies
Oct 16 19:47:40 home-assistant-freedombox[9820]: 2026-10-16 17:47:40.144 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 127.0.0.1, but your HTTP integration is not set-up for reverse proxies
Oct 16 19:48:00 home-assistant-freedombox[9820]: 2026-10-16 17:48:00.805 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 127.0.0.1, but your HTTP integration is not set-up for reverse proxies
  • FreedomBox version: 26.13 debian trixie
  • Hardware: firebat AM02 – AMD Ryzen 16GIB
  • How did you install FreedomBox?: ‘apt install freedombox’
Many thanks for any help.
@windy2 , this issue was fixed in yesterday’s release of FreedomBox 26.14. This release become available to everyone is a few days. Please wait until your machine is updated to this release. Uninstall Home Assistant app and reinstall it again.
Confirmed. 26.14 release came in this morning for me and HA install went fine this time.
Thanks Sunil
The update solved the issue for me. Many thanks!
