The openvpn-client@.service fails to load with the following message:
Options error: In [CMD-LINE]:1: Error opening configuration file: client.conf
When investigating, it seems that file does not actually exist currently. And since the VPN used to work, likely it was mysteriously deleted by some process. However I don’t know what belongs in this file and there appears to be no way to regenerate it - even forcing a reinstall of OpenVPN by deleting it through terminal does not create a new one:
apt remove openvpn
echo "delete from plinth_module where name='openvpn';" | sqlite3 /var/lib/plinth/plinth.sqlite3
Does anyone know how to regenerate this fie properly?
- FreedomBox version: 21.4
- Hardware: Raspberry Pi 4
How did you install FreedomBox?: I believe
apt install freedombox
, but that was over a year ago.
