How do I remove JSXC?
I installed the JSXC app to give it a try, but I will not be using in in the future and would like to disable it. This is possible with other apps.
  1. Login to FreedomBox.
  2. Install JSXC app
  3. Click on JSXC app from menu
I expect to see a toggle to disable JSXC like I do with the ejabberd.
No such toggle exists.
I can only add one image as I am a new user, but the blue toggle is missing for JSXC.
  • FreedomBox version: You are running Debian GNU/Linux 11 (bullseye) and FreedomBox version 21.4.4. FreedomBox is up to date.
  • Hardware: linode
  • How did you install FreedomBox?: ‘apt install freedombox’
reminder , I hav the same question
@wittyrain3499 @eboelens Do you guys have ejabberd installed? It looks like JSXC is a dependancy of ejabberd. You may just have to leave it be (or remove both).
The answer is that you cannot remove it currently. So this is a request for a new feature.
