Hey,
I am very new to the FreedomBox (Yesterday), so sorry for this silly question. But after being convinced to have checked all menu entries (box and cockpit) I can’t find at least one and now I am stuck.
When I was setting up Syncthing, I was worried that my files would be exposed to the internet and therefore unchecked a box labeled something like “can be found through the internet” it was in a long list of options with others similar to “can be found in home network”.
After getting confident enough that the exposure wouldn’t be an issue, I now want to set up openVPN. But it fails and I believe because the Box simply is not reachable from outside.
If you could guide me to where the above described option may be that would be very helpful.
I unchecked a box yesterday which (as far as I remember) meant that the FreedomBox couldn’t be reached from the internet. Now I need to find it to re-check it.
Have a bad memory and do something without proper documentation
Being able to re-check the box
Nothing
- FreedomBox version: 21.4
- Hardware: Raspberry Pi 4 B 2 GB
- How did you install FreedomBox?: Wrote the Image to a Stick according to the wiki entry
Thanks a lot!
