Turning on the services by activating the app fails and returns status code 500.
- Login to FreedomBox.
- Go to application page.
- Click on the activation switch.
- Wait for the answer.
App should start and the WebView should return to the application page with an activated switch.
WebView returns “500 Internal Error […]”
The statusprotocol after trying to activate Coturn app:
020-11-25 21:03:00 CET. --
Nov 25 20:59:57 odroidxu4 /usr/bin/plinth[1236]: # users get-user-groups homer77
Nov 25 20:59:57 odroidxu4 sudo[14951]: plinth : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/users get-user-groups homer77
Nov 25 20:59:57 odroidxu4 sudo[14951]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 25 20:59:58 odroidxu4 sudo[14951]: pam_unix(sudo:session): session closed for user root
Nov 25 21:02:40 odroidxu4 /usr/bin/plinth[1236]: # coturn get-config
Nov 25 21:02:40 odroidxu4 sudo[15342]: plinth : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/coturn get-config
Nov 25 21:02:40 odroidxu4 sudo[15342]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 25 21:02:40 odroidxu4 sudo[15342]: pam_unix(sudo:session): session closed for user root
Nov 25 21:02:40 odroidxu4 sudo[15345]: plinth : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/coturn get-config
Nov 25 21:02:40 odroidxu4 sudo[15345]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 25 21:02:40 odroidxu4 sudo[15345]: pam_unix(sudo:session): session closed for user root
Nov 25 21:02:40 odroidxu4 sudo[15349]: plinth : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/coturn get-config
Nov 25 21:02:40 odroidxu4 sudo[15349]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 25 21:02:41 odroidxu4 sudo[15349]: pam_unix(sudo:session): session closed for user root
Nov 25 21:02:54 odroidxu4 /usr/bin/plinth[1236]: Internal Server Error: /plinth/apps/coturn/
File "/usr/lib/python3/dist-packages/django/core/handlers/exception.py", line 41, in inner
response = get_response(request)
File "/usr/lib/python3/dist-packages/django/core/handlers/base.py", line 187, in _get_response
response = self.process_exception_by_middleware(e, request)
File "/usr/lib/python3/dist-packages/django/core/handlers/base.py", line 185, in _get_response
File "/usr/lib/python3/dist-packages/django/views/generic/base.py", line 68, in view
File "/usr/lib/python3/dist-packages/django/views/generic/base.py", line 88, in dispatch
File "/usr/lib/python3/dist-packages/plinth/views.py", line 167, in post
return self.enable_disable_form_valid(form)
File "/usr/lib/python3/dist-packages/plinth/views.py", line 239, in enable_disable_form_valid
self.app.enable()
File "/usr/lib/python3/dist-packages/plinth/app.py", line 92, in enable
component.enable()
File "/usr/lib/python3/dist-packages/plinth/modules/firewall/components.py", line 56, in enable
firewall.try_with_reload(self._enable)
File "/usr/lib/python3/dist-packages/plinth/modules/firewall/__init__.py", line 167, in try_with_reload
operation()
File "/usr/lib/python3/dist-packages/plinth/modules/firewall/components.py", line 60, in _enable
internal_enabled_ports = firewall.get_enabled_services(zone='internal')
File "/usr/lib/python3/dist-packages/plinth/modules/firewall/__init__.py", line 190, in get_enabled_services
return zone_proxy.getServices('(s)', zone)
File "/usr/lib/python3/dist-packages/gi/overrides/Gio.py", line 295, in __call__
None)
gi.repository.GLib.GError: g-io-error-quark: GDBus.Error:org.fedoraproject.FirewallD1.Exception: INVALID_ZONE: internal (36)
Problem occured first after a power loss. The forced restart let the system work properly.
I can start and stop services without any problems with systemd.
FreedomBox version: 20.18
Hardware: odroidxu4
How did you install FreedomBox?: on armbianOS with Debian10 base
